Question about Danze D403412 Melrose Single Handle Kitchen Faucet with Spray - Chrome...
My danze kitchen faucet is loose and wobbly i cannot seem to tighten it i no longer have my installation insructions. please help. how do i do it?
    Novelist:
  • 152 Answers
You can see the installation manual here:
http://www.ajmadison.com/ajmadison/itemdocs/D403412-chrome_manual[1].pdf
Hope this helps! Remember to rate me, thanks.
Posted on May 26, 2010
Danze D456513 kitchen faucet will no longer swivel. How do I correct this?
The swiveling part may have corroded. You can attempt repair by disassembling the faucet and removing the corrosion or simply replace the complete faucet
Mar 23, 2013 | Danze Plumbing
Bought a home, main kitchen faucet is a Danze NSF
I'm not familiar with a NSF 61/9, but I've used several other models. I believe these are all ceramic disc valve. They almost never wear out. If you remove the handle and the trim cap or bonnet, there should be a nut or adjusting ring you can tighten. Don't over do it. The handle give you quite a bit more leverage than the small tap when it is removed. Here is Danze web site and you can look up your exact model number and see a exploded parts list: www.danze.com
Jul 12, 2010 | Danze Plumbing
What makes the faucet bind?
I'm just installing the exact same faucet and I found that the side to side motion was binding if I tightened the tap too much from the bottom with the nut & "c" shaped clamp with the 2 set screws. Not sure what it could be if yours was fine & started having trouble.
They have support contact info on their website that you may want to try: http://www.danze.com/customer_support.asp
Good Luck,
-David.
Apr 10, 2010 | Danze Plumbing
Faucet is leaking from the cold water line inside the faucet. it is a danze lazio pull out kitchen faucet
Hello
First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
Reassemble,water should stop leaking.
Mar 30, 2010 | Danze D403412 Melrose Single Handle...
Handle is very loose
it ahs to be tightened from under neath the sink.
Jan 24, 2010 | Danze D403412 Melrose Single Handle...
How to get the handle off , it is very loose
Should be a little round button to pry out at lower part of handle itself, and likely an Allen key behind it to loosen off and remove, or tighten to snug up handle.
Jan 21, 2010 | Danze D403412 Melrose Single Handle...
The handle is loose and wobbles
Pry out the red / blue plastic piece in the front and tighten with an ALLEN wrench.
Jan 03, 2010 | Dishwashers
The pullout faucet wobbles when returned to the base.
check that nothing blocking hose return weight under sink
Oct 06, 2009 | Danze D405058 Parma Single Handle...
Danze D403412 Melrose Single Handle Kitchen Faucet with Spray - Chrome... Logo
1,442 people viewed this question
Top Danze Plumbing Experts
john h
Andrew Bugbee
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
