Tempstar Furnace blowing 5 amp fuses
My tempstar furnace (Board is HK42FZ0182006) has blown 5 amp fuses intermittently for about a year. I had a tech come in December and he replaced the transformer, but he also left the wires to the condenser undone. I hooked those back up and it started blowing fuses immediately if I use the fan switch on the Honeywell TH1110D thermostat. I tested the wires for shorts with an ohm meter and they check out. I also tried disconnecting the t-stat wires in the thermostat and I can run through all of the functions (Fan, Heat and AC) by jumpering the terminals directly.. The fuse doesn't blow when I do this (at least for the couple of minutes I've run each mode).
I tried replacing the thermostat with a Honeywell programmable (that didn't use the common line) and it blows the fuse the instant I turn power back on at the air handler.
I put the old Honeywell TH1110D tstat back on and it seems to work fine as long as I leave the G (fan) wire disconnected.
I'm stumped!! Any idea's?
  • 30 Answers
SOURCE: Honeywell TH8000 5 wire
7wires? wtf with that! how many things you got runnin there. you need to give way more info to get a decent reply.
Posted on Feb 04, 2008
  • 69 Answers
SOURCE: Furnace start buts shuts off
It sounds like you have an obstruction in the exhaust vent. Thats why when you bybass the pressure switch it runs ok. Steve
Posted on Dec 21, 2008
SOURCE: tempstar dc90 furnace will not light
Possible solution would be to push the reset button if you haven't already. I have had to do it twice on my dc90 in the last week.
If you look at the glass where you can see the combustion chamber, the glass is oval, follow the long axis of the oval toward the 'top' of the ignition chamber (my unit is laying down, with the blower on the west end and the combustion chamber on the east, as I am facing south). On top of the chamber are two protected spade clips. In between them is the reset. Make sure that the unit is off, press the button, and fire it back up.
Posted on Feb 20, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: 5 amp fuse continues to blow on control board for
You have a short on the 24 volt side of the unit. Check the thermostat wire for signs of pinching or direct short.
Posted on Oct 17, 2009
SOURCE: fuse blow each time I turn on air check for
disconnect the thernostat wires from the control board. Put a jumper wire between R & G put door back on and turn on power. Blower motor
should run, if it blows the fuse then you have a direct short between R &
G at the board. Do this with R and W(heat) and R & Y(cool).
By disconnecting the thermostat wires and reinserting them make sure that they do not touch when inserted into each terminal. If it still blows
that little 3amp fuse when jumpering between each sequence as mentioned above, then I think your board is bad. When Jumpering out the Y terminal you will have to have the AC wires still hooked up. If it
blows the fuse in that sequence. Disconnect the wires out at the condensor.
You mat have a bad contactor at the outdoor unit.
Posted on Jul 16, 2010
Tempstar Air Conditioner wont come on
Sounds like you need a new contactor in the condenser. The low voltage is grounded. Remove the low voltage (likely 2 wires) at the condenser and wire nut the wires leading inside. With an insulated screwdriver manually push in the contactor and be sure both compressor and fan run. Then replace fuse and turn power on to air handler with a call for cooling. Obviously the outdoor unit won't run because you unhooked the low voltage but if fuse doesn't trip then it's likely the contactor. Good Luck
Apr 10, 2017 | Heating & Cooling
DEPENDABLE 92 WON'T START . ALL SWITCHES CHECK OUT. CAN'T DIAGNOSE CIRCUIT BOARD
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
Oct 02, 2011 | Goodman GMS90703BXA Heater
My furnace will buzz but it want come on
Sep 30, 2011 | Coleman Propane Forced Air Heater...
Just replaced batteries in thermostat and now it won't work. Batteries are brand new.
Aug 31, 2011 | Honeywell Heating & Cooling
AC not working, nothing happens
Aug 29, 2011 | Ruud Heating & Cooling
Didn't cool and the fan on the outside unit is not turning
Aug 24, 2011 | Goodman Heating & Cooling
Furnace wont run ...thermostat battery went dead i replaced the batteries and still furnace wont run...We recently had a power outage for approximately 12 hours. This furnace is in our garage. we had...
Hello, The first thing you need to check with a multimeter is if you are getting 24 volts between the R AND C terminal on the intergrated control board. If not than the transformer is blown and needs to replaced or the fuse on the control board has blown and will need to be replaced. When check for 24 volts at the R and C terminal make sure the door switch is pushed in, u can just use electrical tape to temporaily hold the switch in. If you are getting 24 volts at R and C and notthing continues to run than the intergrated control board is most likely the cause and must be replaced.
Feb 04, 2011 | Goodman GMS90703BXA Heater
I have an Amana Air Comand Gas furnace/AC, it's 4
Hi, If you are talking about an led light at the furnace, and it is blank, it should have a 3 to 5 amp fuse that plugs into the board. Pull it and check to see if the metal element is blown or burnt. If so, replace it. If you are talking about some other red light, please let me know. It sounds as though you have lost the 24 volt control voltage, so see if it has a fuse on the board. Keep me posted.
Shastalaker7
Dec 31, 2009 | Heating & Cooling
Thermostat not turning on furnace.
Hi, You need to go to the furnace to see if you have lost the 24 volt supply, the transformer. If you have a circuit board, see if it has a 3 to 5 amp fuse plugged into it that is blown. This will kill power to stat causing nothing to work. Let me no what you find and we can go from there.
Shastalaker7
Dec 29, 2009 | Heating & Cooling
Heating & Cooling Logo
448 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
