Question about Maytag MMV5165 Stainless Steel 1000 Watts Microwave Oven
Our microwave (Model # MMV5165BAS) doesn't sound as loud as it did before. It still works (heats food), but it sounds like a fan is not working like it should when we turn it on. I messed around a little with it and turned on the 5-speed vent fan, level 2 doesn't work. Is this something to be concerned about? Comments: May 26, 2010 - Is the part easy to swap (for a non-technician) and is it worth it?
  • 1,284 Answers
Hi, yes you should be concerned with the fact that the fan in the microwave is not working because it's function is to cool of the microwave whenever it is heating up and without it working, the microwave will gradually begin to malfunction. As a non-tech, it is not advisable to swap it your self because of it's complicity. I advise you call in a tech, and changing the fan worth it.
Take care
Posted on May 26, 2010
Mmv5165bas vent fan will not stop running
Check to see if there's a relay providing power to the fan. If there is, the contacts might be sticking in the closed position. Assuming that this is an over-the-range unit, disconnecting the vent fan completely might not be a good idea as heat/steam from foods cooking on the range would more likely damage the microwave.
Apr 29, 2014 | Microwave Ovens
Fan is loud and almost sounds stuck and the food does not heat at all. Now it died all together. No lights on. Is it worth fixing?
From your the description the magnetron has failed, "heats food" the exhaust fan has seized which keeps the magnetron cool when running, and finally the main fuse has opened, It is far cheaper to replace the microwave oven than repairing it.
Jun 19, 2011 | Jenn-Air JMV9169BAS Convection Microwave...
Our microwave oven started making a loud sound and quit heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101==]-]=-
Feb 14, 2010 | Emerson MW8107WA Microwave Oven
The microwave turns on, but it does not heat the food.
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms ("runs but no heat"), as well as the answers to these questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
- Is there any unusual noise or is it louder or quieter than normal?
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.)
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
http://www.microwavedisplay.com/mwd_ad_aug_2008_background.mp3
Nov 23, 2009 | Magic Chef CMV1000B Microwave Oven
Can't heat food
So we can help you, please post a NEW question, and please include your brand name and the full model number from the tag in or on the unit, as well as the answers to these questions:
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Oct 11, 2009 | Goldstar Microwave Ovens
Maytag Microwave model MMV5165BAS. Doesn't heat
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 10, 2009 | Microwave Ovens
Loud buzzing noise with Whirpool microwave oven when it comes on. All lights, heating and fan seems to work but not sure why loud buzzing. What is the problem?
The loud buzzing you hear is the sound of the magnatron tube.That is what emits the microwave radiation and buzzing should be normal. The mag tube may be nearing its end at witch time you will hear no buzzing and hence no heating of foods. Replacement can be costly depending on the model so most people just opt for a new one. Hope this helps
Jul 30, 2009 | Microwave Ovens
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Microwave does not heat/cook
hi
power spikes are very damaging to a microwaves internal parts, it sounds like your transformer and/or magnetron are blown. if the unit is out of warranty I would recommend calling a repairman or getting a new microwave (the transformer & magnetron are expensive and dangerous to work on) also get a small single plug surge protector for the new one.
Mar 21, 2008 | Microwave Ovens
Maytag MMV5165 Stainless Steel 1000 Watts Microwave Oven Logo
18 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
