Question about Rival RCS200 20-Cup Rice Cooker
Rival RCS200 problem
My New Rival RCS200 20 cup rice cooker is burning the bottom rice
    President:
  • 2,712 Answers
Try this:
  • Before cooking, rinse rice in warm water until water becomes clear. Then place the rice in the inner pot with fresh water.
  • Take care to use proper water to rice ratios.
  • Use a 1:1 ratio of rice to water plus ½ cup of water for white rice and a 1:1 ratio plus ¾ cup of water for brown rice.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 29, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    Should you have any further questions, please feel free to
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    IrishDruid
Every time I cook rice in this rice cooker, the rice is burned & I have to throw it out. Help.
The Manual for the Rival RCS200 Rice Cooker can be found here:
http://www.rivalproducts.com/manuals/MANUALS/RCS200_43_68557881.PDF
Make sure you are following the directions for the correct amount of water to rice.
It could be that your unit is not switching from cooking to warming at completion of the cooking cycle. It should automaticaly turn to the Keep Warm Setting when it detects a temperature of 212 degrees F.
The manual advises that there are no servicable parts. If this is a new appliance I would recommend returning it to the point of purchase. If this is not possible try contacting Rival Customer Service to see if they are willing to assist with replacement or repair: See here:
https://secure.rivalproducts.com/ContactUs.aspx
Oct 26, 2011 | Rival RCS200 20-Cup Rice Cooker
Rice burning on the bottom
i found out if you drizzle some olive oil in the bottom before you add your rice and water or broth this helps alot just a nice color no burning good luck angia in florida
Jun 28, 2010 | Rival RC100 10-Cup Rice Cooker
Where i find sunbeam rice cooker fuse in midrand
sunbeam rice cooker dead
I have a sunbeam rice cooker working fine and all sunden there no power on the rice cooker. I have test the wall outlet power input which is working fine. I assume the fuse inside the rice cooker burn out the fuse. I could not located the fuse from the inside as opend up everything from the bottom panel rice cooker .Please email to me at vancouvercity2001@yahoo.com
thank you
Jun 03, 2010 | Rival RC160 16-Cup Rice Cooker
My rival rice cooker does not work. i plug it in and try to turn it on - the lights don't turn on and the unit apparently doesn't heat up or work at all. tried different outlet - same result. should i...
It is a blown thermal fuse. On 6-cup Rival it is across terminal where power comes into cooker. You can replace thermal fuse for less than a dollar in under an hour. Remove the bottom of the cooker. The thermal fuse is covered by a heat wrap sleeve across input terminal.
Feb 09, 2010 | Rival RC100 10-Cup Rice Cooker
Burnt out rice cooker
hello mam
please follow these steps to fix it
1.check the power cord
2.check the power supply at the terminals of the cooker this can be done if you open the lower cover of the cooker.by using the multimeter or a testlamp.
3.by using the multimeter check the continuity of ON/OFF switch. by doing these tests you can find the fault and can rectify it.
Oct 08, 2009 | Rival RCS200 20-Cup Rice Cooker
I do not have a manual for my rice cooker. Is there anyway I can send for one or download the instructions on how to cook with this cooker.
http://www.jardenstore.com/manuals/MANUALS/RCS200_43_68557881.PDF
here is the website for the manual for you to download and print. if you have any problems you can also just go to the rival website. in the search bar type in your model. a picture will show up click on that picture and then scroll on click down and under the pic it will say model, size, color. under color is the manual. click on that as well. it will pull up in adobe reader.
Apr 29, 2009 | Rival RCS200 20-Cup Rice Cooker
HOW DO I COOK BROWN RICE. LOST INSTRUCTION BOOK
The manual is on the site listed below (its the company's website):
http://www.rivalproducts.com/manuals/RCS200_English.pdf
Aug 08, 2008 | Rival RCS200 20-Cup Rice Cooker
I broke the lid to my RIval RC!00 Rice cooker. Who should I contact?
You can contact Rival HERE.
Mailing Address:
Rival
c/o JCS/THG, LLC
13120 Jurupa Avenue
Fontana, CA 92337
Telephone: 1-800-323-9519
Cheers!
IrishDruid
Apr 26, 2008 | Rival RCS200 20-Cup Rice Cooker
Why does it burn my rice on the bottom.
that is common to have the bottom part burn when cooking rice.
what i did was change the ratio of 5 cups water = 4 cups rice.
when its near cooking, dont leave it for a long time since it will continoiusly heat up in the bottom part, i suggest to unplug it when the rice is already cooked.
hope this will help.
Jan 15, 2008 | Rival RC100 10-Cup Rice Cooker
6 cup rice cooker
its very easy if you put 6 cups of rice= 6 cups of water
5 cups rice = 5 cups water ...equal proportion
Jan 06, 2008 | Rival RCS200 20-Cup Rice Cooker
Rival RCS200 20-Cup Rice Cooker Logo
164 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Ric Shull
Ric Shull
Level 1 Expert
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
