Question about Dryers
I have a maytag neptune dryer model # mde5500ayw it will not start flashing code pf
    Top Expert:
  • Dryers Master
  • 78,919 Answers
In almost all cases this pf code is caused by a defective dryer control board, this board is part of the control panel that u use to set the dryers diff settings and start it into the dry cycle, the board is around $200 but some tests must be performed to verify this is the problem, if u don't know how do electrical testing procedures and don't have required DVOM (Digital Volt/Ohm meter) then by all means call a qualified service technician, Sears is a good choice and sells this line of dryers. below u will find a link to the service manual for the dryer, follow diagnostic steps that start on page 3-1 of that manual, be patient, the manual is a free download but free users must wait a minute to download while the download site tries to sell u the premium service. Link to service manual on PDF file format is below.
http://rs251.rapidshare.com/files/127376784/MDG_MDE_neptune_dryer.pdf
Posted on May 26, 2010
  • 2 more comments
  • jvophus May 26, 2010
    I downloaded manual and read through chapter 3 . Iam familar with volt meters what do i need to test double check that it is a control module
    the dryer starts to turn on then goes off immediatly is this a sensor or control panel.Can I test this what is the procedure
  • yadayada
    yadayada May 26, 2010
    DO THE FUNDAMENTAL CHECKS UNDER THE HEADING OF "DRYER WILL NOT START OR RUN" YOUR PF CODE MEANS THAT THE DRYERS CONTROL BOARD HAS HAD ITS POWER INTERRUPTED, SO MAKE SURE THE DRYER CONTROL BOARD HAS VOLTAGE PRESENT FROM THE WALL, THIS IS THE INPUT WIRES TO THE BOARD, IF U DO HAVE VOLTAGE PRESENT THEN THE CONTROL BOARD HAS FAILED, DID THIS DRYER SHUT DOWN IN THE MIDDLE OF A CYCLE? IF SO WAS IT HOTTER THAN NORMAL? REFER TO THE MANUAL I SENT FOR DIAGRAMS TO SHOW WIRE COLORS TO TEST. BE VERY CAREFUL WHEN TESTING A "LIVE" SYSTEM COMPONENT!
  • yadayada
    LOOK FOR SIGNS OF BURNING ON ALL ELECTRICAL COMPONENTS, DO U SMELL ANYTHING THAT MAY HAVE GOTTEN HOT? READ THE WHOLE MANUAL AND PICK OUT THE SECTIONS THAT APPLY TO WHAT SYMPTOMS YOU HAVE, THAT IS WHY I SENT IT TO U.
MDE5500AYW Maytag Neptune not heating. Heating Element, both high limit thermostats and thermal fuse have been replaced. What could be the problem?
Firstly, you have not mentioned that you have verified the presence of a power source of 240 volts, so make certain of that issue. If you have proper voltage, then the motor centrifugal switch could be at fault
Below is a link for trouble shooting your model.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-4-563862-/Maytag-Dryer-not-heating-MDE5500AYW?r=%2fShop-For-Parts%2fa8b4d563862%2fModel-MDE5500AYW-Maytag-Dryer-Parts
Sep 28, 2016 | Maytag Dryers
Magtag Neptune Dryer - when I press start it say Pause and stops instantaneously. Anyone have this problem and know the solution?
sounds like a bad control board it seems like you have a letter missing in your model number ...I looked up the part ouch ..http://www.repairclinic.com/vwo1/Maytag-Dryer-Model-MDE5500AYW-ID-563862-Circuit-Board-Timer-Parts?s=t-mde550ay-%3d%3dd563862b4a8c13
Aug 14, 2013 | Maytag Neptune MDE5500AY Electric Dryer
My maytag neptune model mde5500ayw make a sound like metal grinding, comes and goes, it looks like the felt liner in the back is loose in one area. Is this the cause of the bloody awful noise?
If the noise is intermittent then most likely the loose felt is not the best problem. More likely is the rollers that support the drum. You can take them off clean and oil with a good bearing oil and that might work or you can replace them if they are too worn
Oct 23, 2012 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag Neptune Dryer stopped running & is
as per heatman The most common cause of your appliance giving you the PF error code is a problem with the power coming in from your utility company. Of course if there is an interruption of power, and then the power comes back on you will get the PF code Loose wires going to the circuit board or the control can also be a cause of the error code. If a wire terminal end happens to get corroded or loose, the vibration from the machine can cause slight power problems and this can cause the PF code to be displayed. Finding the cause of this type of problem is like finding a needle in a haystack. Sometimes you can cause it to be displayed by banging on the side of the appliance or slightly moving the wiring harness, to see if you can get the error code to display.
The bottom line about this power failure error code, is that it is power related. Finding the exact cause can be difficult. If you are continually having to reset the appliance then check to see if all of your appliances are giving the same code. This will indicate utility power problems. If only one appliance is giving the PF code then it is probably internal to the appliance.
Jul 12, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer won't start has power lights will come on but ut won't run flashed PF before it quit
Hello & Welcome to FixYa
PF error code means power failure and is displayed when the circuit board also known as the electronic control board goes bad and needs a replacement. Before replacing the control you can also check the thermal fuse which is inside the rear panel on the blower wheel housing and replace if it reads no continuity. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do you open the top of a Maytag Neptune dryer model #MDE5500AYW
unplug the dryer,open the door and you'll see 4 screws,2 holding the door on and 2 opposite them,remove them and the door,now pull the front off you'll see a clip that looks like an L with a screw through it on each side,take the screws out and lift the top up
Feb 10, 2010 | Maytag MDE5500AYW Electric Dryer
MDE5500AYW MAYTAG DRYER WON'T START
pf means power failure. your dryer uses an extra boost of power on start-up and your is failing to get this boost you need a repair person in your area
Feb 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My maytag will not run
My neptune dryer electric mde5500ayw will not start the button seemed too be struck, and how can i take the side panel off to check the fuses inside
Nov 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
53 people viewed this question
Top Dryers Experts
