Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave goes on but doesn't heat. No buzz or unusual sound. Seems fine just does not heat.
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
3454sr
Posted on Sep 30, 2010
Microwave not heating. It's showing a unusual emblem
  • Open internal fuse
  • Defective control board
  • Defective door interlock
  • Failed magnetron
Apr 21, 2017 | Microwave Ovens
Microwave makes a loud buzzing noise
The buzzing sound could be from loose laminations on the high voltage transformer, or from loose mounting screws for the transformer. This requires investigation by a qualified technician as there are lethal voltages associated with the transformer. It could also be from a loose cover. First check that all the cover screws are tight.
Mar 21, 2014 | Electrolux Microwave Ovens
Sanyo EM-SL40S microwave everything seems to be working fine but food doesn't get hot?
see this causes and fix it. GOD BLESS YOU
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Oct 01, 2012 | Microwave Ovens
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
My GE JVM1842 has an unusually buzzing sound and
That sound usually means you either need to take it to the shop or get a replacement. Yhr buzzing sound is either the big tansformer found inside or the magnetron.
If you have any warrenty this is definitly covered by it. If you don't while it is repairable, the repair cost could exeed the cost of a new replacement. So if you take it to get fixed get an repair estimate before spending any money.
Apr 25, 2010 | GE JVM1842 Microwave Oven
My convection microwave will not heat up in convection mode. the microwave function works just fine. is there a way to troubleshoot and repair the problem?
    usually if convection fails means there is problem in magnetron you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
please do rate me on the above said issue
Dec 30, 2009 | GE JVM1790SK Convection/Microwave Oven
Can't heat food
So we can help you, please post a NEW question, and please include your brand name and the full model number from the tag in or on the unit, as well as the answers to these questions:
When you try to microwave are the inside light, internal cooling fan and turntable all working?
Is there any unusual noise or is it louder or quieter than normal?
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Oct 11, 2009 | Goldstar Microwave Ovens
Whirlpool Model #MH1170XSS-0 will not heat
Since FixYa is not currently notifying us Experts when Clarification Requests are answered, you will need to post a NEW help request.
I
n your new post, please include your brand name and the full model number from the tag in or on the unit and your symptoms, as well as the answer to the following questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
- Is there any unusual noise or is it louder or quieter than normal?
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.)
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 07, 2009 | Whirlpool Microwave Ovens
Loud buzzing noise with Whirpool microwave oven when it comes on. All lights, heating and fan seems to work but not sure why loud buzzing. What is the problem?
The loud buzzing you hear is the sound of the magnatron tube.That is what emits the microwave radiation and buzzing should be normal. The mag tube may be nearing its end at witch time you will hear no buzzing and hence no heating of foods. Replacement can be costly depending on the model so most people just opt for a new one. Hope this helps
Jul 30, 2009 | Microwave Ovens
Ge microwave - making noise
I have a GE counter top microwave oven. When the oven starts cooking (the magnetron turns on) the oven makes a harsh buzzing noise. What is wrong and what should be done?
Mar 07, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
67 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
