Question about Lexmark T640n Laser Printer
MON IMPRIMANTE LEXMARK T640N AFFICHE UN CODE D
Lun. IMPRIMANTE LEXMARK T640n AFFICHE code ONU D ERREUR ERREUR 920,06 FUSER SERVICE
  • 2,296 Answers
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T640n, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Posted on Feb 18, 2011
Erreur 3C10
The 3XX code -fan abnormality.
Feb 01, 2013 | Konica Minolta magicolor 1690MF All-In-One...
BONJOUR JE POSSEDE UNE IMPRIMANTE LASER COULEUR SAMSUNG ELLE NE FONCTIONNE PLUS ET AFFICHE UN MESSAGE D ERREUR SYSTEM ERROR CYCLE POWER QUE PUIS JE FAIRE
Bonjour cevale358 ,
Il n' y a malheureusement pas d' autre solution que de rentrer l' imprimante chez Samsung pour r?paration . Il s' agirait malheureusement d' une panne assez courante sur ce mod?le qui concerne le fusible et l' unit? d' alimantation .. Voici quelques pr?cisions si tu comprends l' anglais ... http://www.fixyourownprinter.com/forums/printer/66821
Cordialement ,
fanaudi .
Aug 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
MON PHOTOCOPIEUR AFFICHE LE CODE ERREUR L 6 SUR LE PHOTOCOPIEUR SHARP AR-205 DIJITAL QUE DOIS-JE FAIRE
L6 = Polygon Motor Lock Detection
Polygon motors are not serviceable items.
Try switching the machine off/on. If the code doesn't clear then you will need to get the motor replaced. Quite often the motor will have made a screeching or rattling noise before it fails.
Hope this helps
Feb 09, 2011 | Sharp AR-M205 Copier
Les deux voyants papier et point d'exclamation clignotes sans repture. salutations
Yat-il un code d'erreur que vous avez trouv?? Le code d'erreur indique un probl?me sp?cifique de l'imprimante, s'il vous pla?t v?rifier et de nous le faire savoir, nous serons heureux de vous aider.
Pour toute assistance suppl?mentaire, s'il vous pla?t contactez le Support technique Lexmark
Jan 30, 2011 | Lexmark E232 Laser Printer
920.06 SERVICE FUSER ERROR
A 920 fuser error indicates that the fuser unit in the printer is below the proper temperature for printing. Turn off the printer for 30 seconds. Bypass any surge device or power strips, plug the printer straight to the power outlet in the wall. Make sure the printer is an operating environment where the temperature is above 16°C (60°F). If none of the steps above correct the issue, the fuser unit or possibly the power supply unit on the printer will need to be replaced. This will require a service action on the printer. I hope I can assist you more on this.
May 26, 2010 | Lexmark T640N Networkable Mono Laser...
BONJOUR MONSIEUR :JAI DES PROBLEMES AVEC MON IMPRIMANTE HP500PS
MY DESIGNJET 500 HAVE THE 79:04 ERROR IT WAS JUST CUTTING THE PAPER WHEN THIS OCURR
Mar 03, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
Solution ?  ,mon erreur E000019-0000
j'ai un problème avec ma IR 3300 il affiche un code E 248-002, que faire? aide moi SVP!!
May 05, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Lexmark T640n Laser Printer Logo
147 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
