Question about Whirlpool Calypso GVW9959K Top Load Washer
Im looking for a code F1 Washing maching stop
  • Whirlpool Master
  • 8,220 Answers
CUSTOMER CONCERN:
Customer has F1 Error Code.
CAUSE:The control is sensing an error in the signal from the air pressure sensor circuit.
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 – CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A – C above, and verified that there are no issues
with the air pressure system.
Posted on May 26, 2010
  • Dan Webster
    Dan Webster May 26, 2010
    Calypso service manual for your model can be obtained HERE
  • Dan Webster
    I think a recall is in effect. You can get another control if you call em.
Error code E35 what is this?
switch off the elec remove lid and check the pressure switch tubing is not been rubbing against the side of the mach and wearing a tiny hole into the tubing .there is sometimes 2 tubes looking from the rear of the mach they are at the left handside not the best place i normally take the rear half of the mach off to gain access .also it only needs apin hole or less to cause bother take care hope this helps
May 06, 2014 | Washing Machines
Recurring F1 code while washing
What is the model number of your unit?
Oct 31, 2012 | Kenmore Washing Machines
I have an AEG 6955 washing maching about 14 years old. Recently the program has stopped on many occasions with code F1 usually on first fill. Other times it works OK. The manual says this is no water....
Yes changeing the valve will fix it . around £30. On one occaision only I have come across the detergent dispensor top being blocked up enough to slow down the fill. on your machine it allows 5mins if this is exceeded F1 is displayed and prog stopped.
Nov 15, 2010 | AEG Lavamat 88840 Front Load Washer
Codes SD and F1
im sorry to say but your main control board to the machine is now defunct aka broken you can find the ecb at marcone appliance online and they will mail you the part directly to your front door hope this helps sorry about the bad news
Jul 17, 2010 | Kenmore HE2 Plus Front Load Washer
F1 error code
check the FixYa website for other solutions for your model, look for one with 29 postings........
Feb 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The washing stops 3 times when you first start it with the codes F1 on display then 3 more times with 19 min. left with the codes F1. What is F1? Everytime it stops I press the stop button then start...
This F1 Code is a Communication disconnection problem between the Control Unit and the Electronic Curcuit Box. First Check the Connection and reply me with the make and model no.
Sep 21, 2009 | Washing Machines
My machine stops and blink f1
unfortunately the only thing you cud look for in errors in washing machines is whether the door is closed properly or not. beyond that u will hav to look for a service technician the codes can be deciphered only by a service technicians of that particular company as error codes differ from company to company. The only thing I cud say is that there is a malfunction of one of the components in the machine sorry but if u hav the manual see if the error code u mention is listed in the manual
Aug 26, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Our washing maching stops running
lid switch is bad. replace switch
Jun 20, 2009 | Washing Machines
F1 error code
replace machine control bd under console
Oct 30, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Calypso GVW9959K Top Load Washer Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
