HI WE HAVE A ATEC LCD TV MODEL NO. AV370W WHICH HAS A POWER SUPPLY FAULT.. THE RESISTER R108 AND R104 GETS BLOWN EVERY TIME WE REPLACE THEM. THE POWER SUPPLY MODEL IS IPLV-42 PLEASE GIVE US SOLUTION ON THIS MATTER. THANK YOU...
  • info54668 May 27, 2010
    HI WE HAVE A ATECHI WE HAVE A ATEC LCD TV MODEL NO. AV370W WHICH HAS A POWER SUPPLY FAULT.. THE RESISTER R108 AND R104 GETS BLOWN EVERY TIME WE REPLACE THEM. THE POWER SUPPLY MODEL IS IPLV-42 PLEASE GIVE US SOLUTION ON THIS MATTER. THANK YOU...
  • 19,396 Answers
Hi.
As far as I know there is no service documentation for Atec TV.
I think the one below is your PSU. Detail from this blog.
Check the capacitors indicated with the arrows, ensured they are not bulged or leaky. If any of the capacitors lined with the resistors had blown, then there will be an excessive draw on the resistor, and this will blow the resistors. Eventually replace the caps and test again.
Here the picture in detail.
Posted on May 26, 2010
  • 6 more comments
  • info54668 May 26, 2010
    WHAT ARE THE VALUES OF R104 AND R108?
    THANKS
  • Ginko
    Ginko May 26, 2010
    Hi.
    If the colors are still visible, try using this chart to find the value of resistors.
    HI R U THERE
    NO THEY ARE BADLY BURNT
  • Ginko
    Ginko May 26, 2010
    Hi.
    Check if the board is the same as the one here: ATEC37LCD_IPLV42PSU_REV_14.jpg
  • Ginko
    Ginko May 26, 2010
    I tried to find service manual.
    All I found were this threads from users with same problem:
    http://www.tv.quuq.org/forum/index.php?t...
    I also found Atec address:
    Atec is built by ONEI UK, 201 Merlin Park, Ringtail Road, Burscough, Lancashire L40 8JY. Tel: 0844 8000266 Fax: 0844 8000267
    Here the website.
    We couldn't find the values of the resistors.
    If a solution can't be found, we may have to go with another engineer. My apologies.
  • Ginko
    Ginko May 27, 2010
    Hi.
    No worries. I am aware that if a resistor is burnt and unreadable there is no practical way to know certainly the value of a resistor. If I was doing the job I would empirically test using a resistor that can fit (eg. try reading multiplier band). The resistors have probably low impedance, and they have been placed there to blow in case of abnormal draw.I do not want to instruct you through the empirical way because there is always chance to blow more components.
    This PSU are factory defective and the schematics had never been made public.
    Please let us know if someone has diagrams for Atec, you will make a favor to the crowd of Atec dissatisfied customers.
    Good luck.
    Ginko.
  • 4,889 Answers
The most likely cause of this problem is a failed voltage regulator. The excess voltage is most likely causing the resistor to blow. Usually most LCD tvs use a 3 pin voltage regulator IC starting with 74xx Ex:7418
I would recommend that you test the voltage accross it and let me know. If you are not sure what the correct voltage for that IC is let me know the IC no and I will help you out.
Sai.
Posted on May 27, 2010
Sharp AQUOS LC-70LE733U
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jun 05, 2016 | Sharp Aquos Quattron LC-70LE733U
Hello, My Westinghouse ltv32w1 LCD TV is only 2 years old. Sound is fine, picture is not so good: Initially when TV goes on picture is okay, then after 30 minutes, the image breaks up into verticlal...
verticle lines are most likely a bad tube or convergence problem. You will not be able to fix this your self . I suspect a bad convergence ic
Sep 17, 2008 | Televison & Video
Tv comes on for a few seconds then starts to blink on screen then cuts off with red light on stays on
Hi Kenny
Being a projection device... Which most TV's aren't ...
You need to break the fault down into the Projection Section or the TV Section.
Or Power Supply Section
Projector bulb blown, overheating etc.
Power supply sensing overload or fault then automatically shutting down.
TV Section may be OK
small internal LCD screen is projected by lens.
Check internals.
Happy Troubleshooting
Nov 03, 2015 | Mitsubishi WD Televison & Video
Sylvania LC321SS9 B 32" LCD, won't turn on
Hi Stephen,
TV won't turn on means the power supply section is dead. Open the back cover if you can. Check up for the blown fuse. If the fuse is blown, replace a new one of the same rating. If the TV works, enjoy viewing and if the fuse blows again consult some TV tech. Never try another fuse with higher rating. It might seriously damage your TV. Good luck.
Apr 10, 2015 | Sylvania Televison & Video
Technika 22-700 standby light flashing
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 25, 2013 | Televison & Video
TV won't turn on. Red light on front stays on all the time but will blink when you push the power button.
hi
this sounds like a fault on power supply board most likly a capacitor 1000uf 25 volt working> look on the power supply board the faulty capacitor will be enlargded on the top it might pay you to replace all the 1000uf cap,s onthe power board. regards windyhouse
Jun 17, 2011 | Digital Lifestyle s LT32323 LCD TV
Describe your ATEC TFT LCD TV AV320w Problemproduct name:TFT LCD TV,Model no :AV320w,system:pal/secam(B/G,D/K,I,L) ,serial no 5CAQS50685,configuration no AV320w-BNP-11EU. I need a remote control for this...
Overseas Model - This is an overseas model. There are no replacement parts for this model in the USA. Please contact the manufacturer directly for replacement remotes. Hope this helps u out. Good luck... HDTV GURU JAY
Mar 17, 2011 | Televison & Video
Due to electric power problem my 26" samsung LCD TV blown up. Is there any safety measure in the form of fuse or circuit breaker in LCD TV's manufactured by Samsung India
Yes. The TV has a solder in 4.5 amp fuse. BUT most of the time when the power surges it also shorts the Bridge rectifier assy. IF you are not familiar with solder techniques, you will have to replace the power supply board. SHOP jimmy has in stock. Use model number .
Feb 18, 2011 | Samsung LA26A450 26 in. LCD TV
I have a 32'' Atec TV when I switch it on the picture stays on for 1 second and then disappears. The sound continues to play! Does anyone know How I can resolve?
It can be bad backlight inverter board or the power that that supply the power to the inverter board. The inverter board itself will have surface mounted fuses which could have blown becuase of short circuits and power surge.
Oct 29, 2009 | Televison & Video
Televison & Video Logo
1,297 people viewed this question
Top Televison & Video Experts
