Question about Nikon N55 35mm SLR Camera
Film will not load in camera and will rewind into can sometimes.
  • 531 Answers
Stripped gears in advance assembly.
Needs service.
Posted on May 26, 2010
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
sorce: http://www.canon.com/camera-museum/camera/film/data/1996-2000/1999_eos3000.html?p=2
Canon Camera Museum Camera Hall Film Cameras
good luck
Dec 20, 2014 | Canon EOS-AE-1 35mm SLR Camera
My 35mm film won't load. It keeps rewinding
Solution: Repair or replace auto-rewind system.
Cause: The built in auto-rewind system that supposed to work when film is finished but because it is faulty it receives wrong signal when film is lloaded. So the camera thinks the film is at the end of the roll.
Possible cost: $65-$75
Oct 26, 2012 | Photography
Rewind stuck on reverse
Hi Luce n Steve, To quote JC at Photo.Net: "sometimes the rewind function "gets stuck" if the camera thinks a previous rewind did not complete successfully. The solution is to reset it by forcing a rewind operation. Just press the two rewind buttons simultaneously: on the left side of the lens and just behind the shutter release. (They are marked and the manual explains how to force a rewind.) I did exactly this, and my next roll of film loaded without problems." Hope that help you folks.
Aug 22, 2010 | Nikon N75 35mm SLR Camera
What does the blinking E in the Nikon n65 mean?
It means "Film remains in the camera after film rewind complete."
If this is happening after shooting, the remedy is simple: open the camera and remove the film. If this is happening right after loading the film, then you've got a more serious problem: the camera is rewinding the film upon loading.
Mar 03, 2010 | Nikon Photography
I finished taking pictures but it didnt rewind. did i load the film wrong? or did the batteries die? or whats up
Have you tried taking just one more pic to see if that triggers the rewind? If that didn't work, most film cameras have a rewind button. Usually on the bottom of camera. If you still can't get your film to rewind, take camera to your nearest photo finisher. They should have a dark box; they can remove your film manually.
Feb 18, 2010 | Canon EOS Rebel K2 35mm SLR Camera
How to load new film
push the rewind button on the bottom of the camera, then turn the rewind knob to the right to rewind any film that may be in the camera. Lift the rewind knob up to open the back door. remove the film canister if there.
on the new film canister pull enough film to reach the take up spool. attach the leader to the spool and close the back door, advance the film to counter number 1. enjoy.
Oct 07, 2009 | Minolta XG-A 35mm SLR Camera
Can't advance film, press shutter, no result
Do you have film in the camera? If so, is it an old film or you have just loaded it?
If it's an old film, could it be at the end of the roll - to check this, 'lightly' turn the rewind lever backwards and forwards. As the camera is pointing away from you, turning the rewind knob clockwise will normally rewind the film (don't press the rewind button in, we don't actually want to rewind the film yet), turning the knob clockwise should be tight and a firm stop, if the film is at the end, you will feel the same tight firm stop if you turn it counter-clockwise. Don't turn the rewind knob backwards (counter-clockwise) too hard, you'll unscrew it and it may fall apart. If turning it backwards rolls freely in a full circle, then you have film left.
Another option is that, since it's been so long since you used it, the loading of the film may have gone amis and sometimes the cassette will flip backwards, jamming the film in place so it wont advance - if you have loaded the film and not taken any pics or have not been able to advance it at all, it should be safe to open the back as the film will be in it's original loading position, if you have left the film in it from some time and don't know what stage it's up to it may be best to take it to a camera store where they will have a "Black Bag" to put the camera in and manually open and unload the film. Make sure you get an experienced person - some pimply-face teen that's never used a film camera can easily put their fingers through the shutter while it's in the black bag - I've seen it plenty of times.
OK, that's enough to get started, did this work or do we need to try more options?
**.The best way to acknowledge contribution is to rate it's relevance.**
Feb 03, 2009 | Canon EOS-AE-1 35mm SLR Camera
Rewind runs but film still seems stuck & won't rewind-Max 3xi
It could be that there is a broken or missing gear in the rewind. It will spin but not catch. Sometimes when film is loaded it, is not drawing the film across and missing a gear, so it seems like your taking photos and its not. If you sent it to minolta, good luck, they were bought out by Konica, and probably didnt' do a thorough analysis of it.
I have a friend who fixes cameras. Cleans them, lubricates them, and callibrates them,
http://www.cameradr.com/
Hope this helps you
Nate
Dec 30, 2008 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Loading film
there's a tiny black button to the side, beneath the rewind lever, press that as you pull up on the rewind lever
Oct 26, 2007 | Vivitar V3800N Zoom 35mm SLR Camera
Nikon N55 35mm SLR Camera Logo
114 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
