Question about Boating
I need a new control board for my Minn kota MKJG
Can someone repair a Minn kota control board for a model MKJG auto pilot?
    Top Expert:
  • 47,630 Answers
Possibly someone could but the cost will prohibit it new boards are a lot cheaper if you can get one .http://www.trollingmotorparts.com/
Posted on May 30, 2010
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    WHO STOCKS A 2991251 CABLE FOR A MINN KOTA
    Sherry, I think there may be a new Minn Kota part # . Check the attached links. Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Minn Kota Power Drive Non Auto Pilot Coil Cord Assembly 2991283
    Minn Kota Trolling Motor Part COIL CORD STRN RLF PD48 54 2991283
    http://minnkota.com.au/wp-content/uploads/2014/07/55-PowerDrive.pdf
    Can get replacement parts for my Minn Kota trolling motor FAQs
    Apr 13, 2016 | Minn Kota Boating
    Minn kota
    I have a terrova with i pilot same thing happened found out it was the remote, if thats not it then you will more than likely have to send it in for repair.
    May 13, 2014 | Minn Kota Riptide Sp Saltwater 70 Bow...
    Minn kota riptide 55 bow mount with foot control and auto pilot. problem is prop doesn't seem to spin as fast so top speed is about half to two thirds of what it was when new. unit is about 5yrs old.just...
    Sounds as if the motor has either bearings going bad and/or water has gotten in the housing washed the lubricants out. Motors do wear out eventually. I'm not sure if the brushes are replacible. Have you checked for any constrictions like fishing line? And also the contacts on the controller could have minor corrosion meaning take it apart if possible and clean with steel wool or a dremel.
    Oct 16, 2010 | Minn Kota Riptide St Saltwater 55 Bow...
    The motor has two speeds. Very fast forward and very fast reverse. The speed control is not functioning
    A lot of these units have 2 year warranty. Minn Kota web site list authorized warranty repair centers. The foot control unit most likely got water in the digital switch. If not under warranty any longer, open it up and see if any water bubbles in the sealed board where speed switch makes contact. If so you will need new foot control.
    Sep 30, 2010 | Minn Kota Powerdrive 68PD V2 Pontoon Motor...
    Trolling motor stays on same speed no matter where I set the speed 10 -100. It is at a mid range speed.
    I just recently had a simialr problem. No speed control and motor only ran at 100. I talked to the minn kota tech rep and sent him my control board and he said it had a bad potentiometer...however, I had to buy a control board to fix the problem ($215). Hate to say it but sounds like you may need a new control board.
    Jun 24, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Riptide RT65 24 volt with auto pilot goes nuts.
    your magneto is shorting [ arcing on high needs, openup and replace magneto. call minkota and order a new magneto for your model, unless under warrantee.
    Apr 13, 2010 | Minn Kota Riptide Sp Saltwater 70 Bow...
    Minn Kota 24v auto pilot. will track correctly
    Usually this means that there is a crack in the coil cord or there is something metal close to the head of the motor.
    The coil cord can be checked while you are out fishing next time by grabbing the cord (black coiled cord from base to head of the motor) and stretching it and pulling on it. If the motor reacts to the pulling then that's the problem.
    best of luck!
    Mike
    Jun 20, 2009 | Minn Kota 55 AutoPilot Universal Sonar...
    Boating Logo
    231 people viewed this question
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
