On my MultiPass MP700 I'm getting vertical lines on eveything I print. I've run cleaning, deep cleaning, alingment and nozle checks. On the checks L & M the lines (stripes are horizontal alternating black and brown on every pattern. It goes away after printing about 20 copies .
  • 1 more comment
  • Doc45 Apr 07, 2008
    I have no idea where the drum is
    This is coming out on every sheet when printing from the computer, certificates, business cards, etc.
    I will try to find a repairman in Las Vegas or Henderson
  • 871 Answers
Hey doc45
whenever you eep on printing those black an brown lines on paper, that means that your printer is experiencing faulty drum. this is a common problem for printers which is used overtime.
in regards to ser71,maklean,eagle338 posts...
wat you could do is do a quick fix like these experts has posted. if you do experience same problem... you could also try doing the maintainance steps on the manual which indicates that if there is stillno improvements on the ink printed on the paper, you may want to replace the printhead.
just to be on te safest side, find a replacement printhead for that so that you'll be able to use your printer in no time.
Posted on Apr 07, 2008
  • 4,889 Answers
Hold the print head over a steaming kettle take care not to scald yourself. The ink will run out of the bottom of the printhead just dab on a piece of paper towel, when you see black you will have cleaned it. I dont know if this will do any long term damage to printhead but it has worked three times for me
  • 818 Answers
  1. Lift the document cover to expose the platen glass.
  2. Wipe the platen glass (A), white areas (B), and transparent sheet (C) with a clean, soft, lint-free cloth moistened with water. The MP700 has one even platen glass and does not have an area like the one referenced in area (C).
  3. Then wipe with a clean, soft, dry, lint-free cloth making sure there are no residues left, especially on the platen glass.
  4. Close the document cover and make a copy of a text document to confirm the black line has disappeared.
    Genius:
  • 1,665 Answers
It is your printer drum dirty
Alarm on: reads wrong cartridge in window
Problem may be due to your not printing for quite some time. The ink can start to dry and clog the print heads.
Use a Q-tip slightly moistened with water to clean cartridge ports and print head.
Jun 13, 2010 | Canon MultiPASS MP700 All-In-One InkJet...
Missing Column G on print head align printout!
can you please try a test page...and report back what that looks like..
Oct 15, 2008 | Canon MultiPASS MP700 All-In-One InkJet...
Prints have lines throughout
Sounds like the printer head is dirty and needs to be cleaned. If after removing the ink cartridge and cleaning the print head with DENATURED ALCOHOL NOT RUBBING ALCOHOL, does not produce clean prints with out the lines, you might need to replace the actual print head mechanism. The print heads do not last forever and need to be replace every so often.
Cheers,
Keith
Sep 19, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Cant remember how to clean the printer heads
go to start>settings>control panel>printers and faxes> then right click the printer and click properties.
Then click the services tab, there you can run all the "cleaning" utilities available.
Thank you,
Le
May 27, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Lines appearing across printed photographs
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Deep cleaned black nozzle several times, but still splotchy printing
I have the same promblem, after changing th print head.
It priints black if I change the paper to photo paper.
May 13, 2008 | Canon MultiPASS MP700 All-In-One InkJet...
I had the same problem. My 4 year old MultiPASS MP700 started banding magenta stripes across everything I printed.
I suspected the cyan printhead was clogged because the printhead tests showed two of the cyan columns as half missing.
Canon was less than helpful. I went off of my suspicion that I needed a new printhead. I found one from an online supplier for 50 bucks...better price than a new printer! I put the new print head in and it works like new.
http://www.precisionroller.com/print-heads-for-canon-multipass-mp700/products.html
Jan 14, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
My canon multipass f80 printer makes colored bands (1/8 of inch) through the pictures
Prints heads have to be alinged and or you let it sit too long without print and your print heads have to be cleaned
Dec 08, 2007 | Canon MultiPASS F80 All-In-One InkJet...
Canon Multipass MP700
When trying to print color documents or photos using our Canon MultiPASS 700, the photo or document will have stripes all the way through it. It has also developed a problem of having fine lines that do not print when we are printing a black and white document.
Dec 03, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
jasbo
jasbo
