Question about Motorola Mobility RAZR V3c Cellular Phone
Charge problems I can plug the phone into the charger and it takes 8 hours for it to show a full charge, when it used to charge in less that 3 hours. It also only hold a charge for a couple hours when I could go days before. So I did what most people would do and I replaced the battery and I still get the same behavior. The phone also gets very hot when charging.
  • 59 Answers
Its because of a faulty charger more than the battery but you could try changing the battery and charger both that should improve the results.
but the piece getting hot might be due to moisture in the piece thus a shorting of some sort, my advice switch to a different piece sell it off, as the v3 circuitry is too complicated for repairs.
Posted on Apr 07, 2008
Why doesn't the motorola P4000 not hold a charge after charging it for several hours
Your battery is shot. Rechargeable batteries only last so long.
Feb 08, 2015 | Motorola Cell Phones
Recently i have purchased Motorola S9 blutooth head set. Kindly let me know what type of motorolla charger to be used 1.5amp or 2 amp since there are 2 chargers available. And also while charging, within...
Bluetooth headsets, like many portable devices can be charged on a USB port on a computer, which supply less than 1A, so either charger would be suitable.
Looking at the manual, a full charge should take two hours, so half an hour seems a little quick.
Perhaps it was part charged?
You could see if you can listen to music for six hours on a charge, and if so how long it takes to charge then.
The manual can be found here.S9 user guide - Motorola
Feb 14, 2011 | Motorola Mobility S9 Headphones
Just got a Mag One BPR battery delivered to me and i put it on the charger. After about an hour the green light is on. I thought the battery needed to be charged for 8 hours the first time? Why the green...
The charger which comes with the BPR40 is a rapid charger. (The book doesn't indicate if it is a 90 min. or 3 hour charger.) None-the-less, your battery is fine. When your charger is displaying green it will continue to trickle (slow) charge the battery to keep it topped off, so to speak. The first 3 charge cycles you should leave the battery on the charger the full recommended time. On most Motorola radios it is 10-12 hours. This will assure your battery is charged to full capacity and initiated properly. In most cases, your traditional charging of the radio should be overnight. When you go to bed, put the radio to bed on the charger.
FYI: All batteries come from the factory with some charge in them. It is a small test charge to assure the battery's funcationality.
If for some reason after the first week or so, you think your battery or charger is not functioning properly, contact the dealer where you purchased the unit. They can replace it under warranty.
Best regards.
Dec 29, 2010 | Motorola Mag One BPR40 Two Way Radio
Charging problem
there is nothing wrong with your charger. The problem is from your battery.
The battery cell is very weak, such that it does not have the ability to with hold power for long.
Therefore, get another battery and the problem will be resolved. But make sure you charge the new battery till its full before you start using it.
Take care.
Mar 10, 2010 | Nokia N70 Cellular Phone
DSealed Lead Acid Batteries: 12v 7ah; belongs in a Liftmaster LA400 gate control box. Can these batteries be charged using a trickle charger? I'm trying to find out if it's the battery not holding a charge...
Yes you can charge the 12 volt bttery on a trickle charger. You should use a 1 amp or less charger. Check the battery every 1/2 hour or so for heat. If it get's hot you should stop charging. Power packs that have a 12 volt rating will charge your battery safer and better but will take longer (like a cell phone charger) look at the voltage ratings on the charger. You will have to adapt the plug to hook it up and test for correct pos. and negative connections. The 7amp hour batery should be fully charged by a .5 amp (500ma) charger in about 14 hours (multiply the amps times hours of charge and do not go over the 7amp hours of the battery when deciding how long to charge). After charging check voltage, it should be around 12. Let the battery set for a few hours (overnight) and check the voltage again. It should be around 12 still. A fresh charge will usually show a higher reading (called a surface charge) than a battery sitting around. 4.5 v will not operate your device, 9.5 v or higher should.
Aug 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
My iphone shows charging but will not charge
this could be a software problem
or else the charging socket problem
it is best u take it to the apple store
May 27, 2009 | Apple iPhone Smartphone
Battery problems
You need to replace your battery.  When you do follow these steps to preserve battery life.
1.  Fully charge battery for 24 hours 2.  Make sure that you use the phone without charging it until the phone tells you the battery is low. 3. Fully charge the battery until it reaches full again.
The reason your battery is failing to hold a charge is a problem call battery memory.  The less power that you use off the battery the less capacity the battery has.
Jan 04, 2009 | Nokia 7270
Sidekick 3 battery problems :(
what you do is get a new battery and if that does not help the situation then take the phone into a service center to have it check.
Jun 17, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Stops while talking
Hi folks with aging JAMS. My JAM is still dying (complete shutoff) using phone. I wish it would just lose the phone signal but my unit shuts off completely during phone calls. I can have 80% charge. I spoke with a friend that mentioned on his cell phone (different manufacturer) that although his battery will show a full charge or less, the time it takes for the charge to go down is ridiculously fast once the battery is old. He watches his phone lose a charge in under an hour though it charges to full.
I wish IMATE would make some formal post regarding when to get a new battery and what symptoms are possible. I'm a bit hesitant to invest in batterys if the issue is hardware. I use the unit alot--as a PDA, a phone, etc. It gets jostled about so maybe something is lose inside, though I doubt it.
I purchased a cheap phone charger so in the car I'm recharging and at work I just keep a cheap USB to plug charger. I reserve the phone when I'm out. This is not really optimal for cell phone use but it's a behavioral fix. I figure I should be looking at a new device (despite high prices) soon.
I did a full discharge/charge cycle or two or three but only noted short term benefit. At some point the quirky behavior returned and off went the PDA cell with the 80% charge. I see dots of us around the net. Again my Jam is probably 3 years old this March.
Oct 28, 2007 | i-mate JAM Pocket PC
Motorola Mobility RAZR V3c Cellular Phone Logo
76 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
