Put player on progressive scan and now unable to get it back or view dvd or rest player is there a way to reset player to manufacturer settings
  • johnhalpin May 04, 2008
    this didn't work disconnected for days
    GOVIDEO model 2150 tried suggestions from disconnecting for a day and plugging back in and unplugging it and holding the POWER and Menu buttons at the same time as I plug it back in still stayed on Progressive scan
    Genius:
  • 3,422 Answers
HI,
Please give the make and the model no. so that i can help you fix it.
Waiting for your reply..
Posted on May 01, 2008
  • 563 Answers
Hi Johnhalpin
Yes , unplug the unit and plug it back in , but hold in your power and menu buttons on the unit when you plug it back in.
Should do the trick.
Posted on Apr 21, 2008
    Guru:
  • 1,894 Answers
Just do a hrad reset sir.
  • dewan nafees ahmed Apr 21, 2008
    hard reset is done by totaly disconnecting it from the power for few hours.
    you are done
SOURCE:
I can't turn the video ouput on.
It may be a variety of things:
1. Make sure your TV is set to the right input for the cable you are using (Composite, Component, HDMI, etc.).
2. More often then not progressive scan may be set. If your TV is not compatible with progressive scan then you must try the following to turn it off:
  • Look for an external button or remote control button that turns progressive scan on or off.
  • Remove any discs from inside the DVD tray with the power on, then hold down the Stop button on the front of the DVD player for about 10 seconds to see if this will reset the system to default (i.e. no progressive scan).
  • If this does not work, you will need to contact the manufacturer for the exact reset steps for restoring to default settings.
3. Lastly, the video processor could be malfunctioning. This would mean a technical repair.
Hope this was helpful. Thanks for visiting FixYa.com
Feb 15, 2011 | Apex Digital AD-2500 DVD Player
Progressive scan, no pictures on tv
Hold down stop button and turn on standby button this will reset to normal mode.
Mar 12, 2009 | Pioneer DV-270-S DVD Player
Picture is split -- says P-SCAN. It's stuck
that means it is stuck on progressive scan.  If your tv is not able to handle progressive scan, you need to change it back or reset the player.
The DVD player may be set to Progressive Scan Mode. You will need to change it to Video Mode by using the remote control. Point the remote control directly at the DVD player, and then press the PSCAN button 2-3 times. If you are still encountering problems with the DVD player, reset the unit back to the default setting.
To Reset,
Make sure you do not have a disk in the tray. Using the DVD player remote control: 1) Press the “Setup” button. 2) On the “Down” arrow, press it three times. 3) On the “Right’ arrow, press it once. 4) On the “Down” arrow, press it three times. 5) On the “Right” arrow, press it once, then press “Enter”. 6) Press the Setup button. *The default setting will take affect as soon as you press the setup button (step 6).
Hope it helps..please rate!
Mar 07, 2009 | Coby DVD-224 DVD Player
Lost picture when set dvd player to progressive scan.
Hello Fearlessloki, Welcome to Fixya.
Would you mind posting some of the details on this DVD player that is having issues?
Jan 05, 2009 | Cyberhome CH-DVD 300 DVD Player
RDR-VX515 IN PROGRESSIVE MODE
just press and hold the pause key on the unit for about 5 or 6 seconds and the progressive mode light will go off and the picture will come back.
Nov 11, 2008 | Sony RDR-VX515 DVD Recorder/VCR
Player was put on progressive scan and has stop displaying any video
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
May 15, 2008 | Cyberhome CH-DVD 300 DVD Player
Progressive Scan
Press open for the dvd. While it is open press progressive scan but and it will reset.
Apr 17, 2008 | Samsung DVD-V4600 DVD Player/VCR
Progressive scan
I have a zenith dvd/vcr receiver model LH-C245M i accidentally put it on progressive scan mode and appears on on my TV screen how can i get back to normal viewing? can you help me with this one Please. Thank you hoping for your great response.
Jan 11, 2008 | Progressive DVHE210 210 DVD Player
Progressive Scan
Hold the stop button for about 10 seconds. The other thing to do is move the video out cable at the back of the DVD to one of the component outs (there are three of them one for each color rgb) you will be able to read the menu again. turn off progressive scan and reconnect the video cable to dvd out
Jan 04, 2008 | Zenith XBV442 DVD Player/VCR
Picture problems
Scrolling/black-and-white/"out of tracking" display on a DVD player is generally caused by the DVD player being switched into Progressive Scan mode on a TV not capable of viewing that content. Scan the remote for a button labeled Progressive, I/P, P.Scan, or anything similar. Scan the user manual for information on resetting this also. If the manual and remote come up dry, call Protron and see if there's a key combo you can hold to reset that. Often, holding Play for 5-10 seconds will reset to standard (Interlaced) mode, or holding Stop while turning the unit on. Sometimes, holding Display on the remote for a few seconds will also switch this setting. Good luck.
Jul 11, 2006 | Protron PD-800 DVD Player
Televison & Video Logo
Top Televison & Video Experts
Ekse
