Question about Sanyo DP19648 19 in. LCD TV
I have a sanyo ce19ld86dvb television when i plug it in and it starts up into standby mode as normal, then i turn the unit on with the remote or the telvision manual controls in turns on but goes straight back into stnadby mode. what does this mean and is it fixable?
  • 62 Answers
SOURCE: Sanyo television is stuck on
I would go for the 4 hours because it will the give television to longest time to recover from whatever issue it is having. In fact, just to be sure, leave it overnight. This will insure that a full reset will take place.
Posted on Jan 09, 2009
  • 188 Answers
SOURCE: my television is in standby mode and wont tuen on
I guess the power supply went broke,look for bad caps or the main power FET / IC is broken.
Posted on Jul 23, 2009
  • 12 Answers
SOURCE: 3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Posted on Dec 16, 2009
Testimonial: "while we did not unplug the set, we let it sit for 2 days and we were able to turn it on by the remote & manually....does that still sound like P/S"
brownline45
  • 310 Answers
SOURCE: I have lost the remote to my sanyo DP32746 32 inch
just go to sanyo service center to buy a new remote control, to fix your problem
Posted on Jun 19, 2010
taran_2005
  • 10515 Answers
SOURCE: My Sony LCD TV Model KDL-46VL150 will go to
This isn't good. A 6 flash shut down means there is a problem with the backlights inside the panel.This TV was initially introduced in Oct 2009. If you might have bought the TV within last year or so, try to call Sony and check, if they would repair this without any fee unless this would be an expensive repair. This is really common problem on this set and reported many times.
BAD NEWS - Even though it is a problem with backlight inside the panel, it cannot be replaced alone. The complete panel has to be replaced.
The only option i could suggest is to contact Sony and urge for repair.You need to tell them that you are aware that this is a common problem on this set and there is a probability they could repair the TV and charge you only for parts. This is the only possible resolution. I always urge all the people who bought these technologies to buy extended warranties to avoid these situations.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 13, 2011
How to get Sanyo dp50741 out of hotel mode?!
This is for Panasonic but might help you
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the AV/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above.
Read more: My 50" sanyo plasma tv is stuck in hotel mode how do i get it out of hotel mode? - When i turn the tv on it says D01--32 and a blue lower case u under it :: Ask Me Fast at http://www.askmefast.com/My_50_sanyo_plasma_tv_is_stuck_in_hotel_mode_how_do_i_get_it_out_of_hotel_mode-qna4904417.html#q5129429
Nov 28, 2015 | Sanyo Televison & Video
Safe/dynamic mode appears on the screen for half a second
You have a power supply problem.Most brand they have modules.
If you can open the back you will see a few separated Modules.You
will see a power supply module just replace it Take note of the connectorsThey have letters usualy to match the plugs.
By the away do you have any sound?
Nov 01, 2012 | Sanyo Televison & Video
When i turn it on it clicks and the goes right back off
New set?
If you're turning almost any TV on by the manual power switch on it, thats Standby mode.
The next step it's waiting for is the ON command from the remote control.
There are two main methods remotes use to go to ON from Standby:
Press the Power button for both on and off commands
Press any 1-10 (or 1-0) button for on, press power button for off.
Sep 24, 2011 | Sanyo DP42848 LCD TV
The TV worked fine on Sunday evening, turned it off the normal way when went to bed. Came down to turn on in the morning and only the red light comes on indicating standby mode. I have unplugged...
There seem to be a problem that is why the television is not coming up and stays stuck on standby mode.
First try to turn on the television using the remote of the television and ensure that the battery of the remote is properly working, you can as well try to push the channel button on the television if the remote does not work.
If it does not come up both by using the remote and pushing the channel button, then it means it is a hardware problem, and that is from inside the unit of the television. Since the standby light comes up, it simply means power is reaching the main panel of the television.
This mainly used to be caused by a faulty or bad capacitor on either the main panel or the power panel of the television.
To check and fix, follow the steps below:
Dec 07, 2010 | Insignia NS-LTDVD19-09 LCD TV
I need a code for my sky remote for my sanyo tv in order to get the volume working It is a sanyo 32" Model CE32LD33-B-01
with the tv on and sky off, press red button & select together, remote blinks twice.press tv then standby repeat this action until the tv turns off. when it goes off press select. press standby again and tv should start. your sky remote should then work perfect. as a tip with tv on and sky off press tv then back up this should then go to the freeview setup and you can watch those as well for free
Sep 09, 2010 | Sanyo Televison & Video
Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Oct 03, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
No pic or sound
First unplug set and let set for several minutes the plug in and turn on. Could be in a serv mode.
Jul 13, 2009 | Hitachi 51F59 51" HDTV Projection...
Earlier; Fisher stacker type unit. stuck in Standby. mode
Hi jamz.
I see this is a pretty ancient posting so you've probably fixed it or given up by now.
I also own a CA-350 Amp which I purchased many years ago here in Auckland NZ.
I've recently had it in bits to fix so if you're still looking for a solution I may be able to offer you some help.
If so, you can contact me at martymarvel@hotmail.com
Oct 25, 2007 | Audio Players & Recorders
Sanyo DP19648 19 in. LCD TV Logo
129 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
