Question about Kenmore 44102 Front Load Washer
THE CYCLE SAYS NORMAL, 45 MIN. IT TAKES ABOUT 4 HOURS, IT KEEPS RUNNING AND RUNNING. THIS IS A NEW PROBLEM. IT IS NOT BECAUSE OF "SUDS" OR ANYTHING I EVEN TRIED DOING A LOAD WITH NO SOAP TO SEE. THIS WASHER HAS WORKING FINE, THEN I JUST MOVED AND I DON'T KNOW IF SOMETHING GOT BUMPED AROUND IN THE MOVE...PLEASE HELP!
  • 3 Answers
Check water feed pressure
Posted on May 26, 2010
How long does the 55 degree normally run for
Depends on the water temp going into the machine. Dishwashers should be connected to cold water. Some people fit to hot water but the machine will go through the cycle too fast and you wont get a decent wash result. 55 isn't superhot for a machine (I assume this is 55 celcius?) Most machines will take about 45 mins to an hour.
Jan 03, 2015 | Dishwashers
Zanussi progress 1200
check the filter for blockages
May 01, 2014 | Washing Machines
I'M GETTING A SUDS F35 CODE
Hi
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
-Run the unit through a Rinse/Spin cycle.
-Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer stops and suds flash on the display
Sud: Suds lock (overdose of detergent detected during wash cycle)
The motor control unit senses a suds lock condition by analyzing the
current draw on the drive motor. If "Sud" is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
excessive detergent, or excessive suds.
Possible causes/procedure:
or kinked.
Use your tech sheet for diagnostics it is behind that panel the Handy Hippy showed you how to take loose (see above link) Use this MANUAL for Duet sport as a guide for repairs
Thanks for using fixYa
Jan 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher control light blinking
1 Press down the overfill protection float on the floor of the dishwasher's tub in the right, front corner near the door. If it cannot move up and down freely, the "clean" light will flash.
2 Make sure the dishwasher's water supply is turned on.
3 Look for suds on the inside of the dishwasher and wipe them off with a wet cloth. If the washer's sensor detects suds or foam, it may not run. Use the correct amount of dishwasher soap, not hand soap or detergent for washing dishes in the sink, to ensure suds and foam do not form. Also, make sure the cap on the rinse aid dispenser is secure--this will keep suds and foam from forming as well.
4 Close the dishwasher door. Push the "normal wash" button, then push the "heated dry" button. Push the "normal wash" button again, and push the "heated dry" button again.
5 Watch for all of the lights on your Kenmore dishwasher's panel to turn on and then turn off. The washer may start a new wash cycle at this point; if you do not want it to do so, press the "cancel" button. Otherwise, allow the dishwasher to run through this cycle.
Nov 25, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
F35
Hi, Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Take care
May 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Tried to wash a load of clothes and keep getting an error code "sub". The machine will not complete a cycle, won't rinse, etc. What does the error code mean and how can I fix it?
SUDS LOCK (OVERDOSE OF DETERGENT
DETECTED DURING THE WASH CYCLE)
current draw on the drive motor. If “Sud” is displayed a potential Suds
Possible Causes / Procedure
■ If too much detergent was used:
or kinked.
cycle.
Mar 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing time & quality
Look for wash cycles in your users'manual. It is best the read the manual well before operation.
Apr 05, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Kenmore 44102 Front Load Washer Logo
49 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
