Question about Lexmark T640N Networkable Mono Laser Printer
920.06 SERVICE FUSER ERROR
920,06 ERREUR FUSER SERVICE
  • Official Brand Answer
  • 3,344 Answers
A 920 fuser error indicates that the fuser unit in the printer is below the proper temperature for printing. Turn off the printer for 30 seconds. Bypass any surge device or power strips, plug the printer straight to the power outlet in the wall. Make sure the printer is an operating environment where the temperature is above 16°C (60°F). If none of the steps above correct the issue, the fuser unit or possibly the power supply unit on the printer will need to be replaced. This will require a service action on the printer. I hope I can assist you more on this.
Posted on May 26, 2010
Qu'est peut on faire si la machine ca,o, IR2318 donne erreur 0000007-0000
hello sorry but another time try to use the language which can easily be read and thats English back to the point the cause of that error is the rotation of the fixing film is detected.
The reading of the main thermistor is 100C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven try to check on that fuser film if the error persist change the fuser unit
Jan 13, 2017 | Office Equipment & Supplies
Erreur cod 009-330 xerox 7245
009-330 error code xerox work center 7345 problom & soluson
Jul 10, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Rebooter
The problem is in the fusing unit,fuser warm up error.Enter in the service mode:Press utility key Meter count key introduction 00000000 press enter select trouble reset.
Jan 24, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Ma photocopieur shar 5516 marque un message d'erreur H4
H4 error indicates the fuser is faulty and should be replaced.
Jun 19, 2011 | Sharp AR-5316 Advanced Digital Imager...
And what do we do for the E04-02 Erreur machine on Panasonic DP 4520... when after service hour - rush...
The code can be reset in service mode, LBP fuser reset.
E04-02 indicates a jamming problem in the fuser unit, usually accordion jams. Correct the fuser problem prior to resetting the code.
Mar 05, 2011 | Panasonic Workio DP-3520 Copier
Erreur 5930 for hp 5550dn
59.30 is a fuser motor startup error.
Could be a bad fuser drive assembly or a DC Controller.
Have a technician look at it.
Feb 02, 2011 | Office Equipment & Supplies
Kyocera fs 1016 mpf printer error service call 6400
Code: 6400
Zero cross signal error
While fuser heater ON/OFF control is
performed, the zero-cross signal is not
input within 3 s.
Causes:
- Defective the power source PWB
- Defective the engine/high voltage PWB.
Dec 15, 2010 | Kyocera FS-1016 Printer
MON IMPRIMANTE LEXMARK T640N AFFICHE UN CODE D
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T640n, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
May 26, 2010 | Lexmark T640n Laser Printer
Showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
May 31, 2009 | Kyocera FS-1118MFP Laser Printer
Lexmark T640N Networkable Mono Laser Printer Logo
2,983 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
