Sony LCD Projection Tv Model KDF-E50A10 made 2005 - the remote or the power button will not shut off tv - where to find good repair manual on this tv
  • 8,617 Answers
I work at another site as a repair tech that sells manuals and provides free tech support. We just loaded that model yesterday from our server. Its 241 pages the full factory service manual and sells for 15.99 they email it within minutes of purchase and you get free tech support to help you with diagnosing and repair. heres the link.
http://servicemanuals.vstore.ca/
Posted on Apr 07, 2008
I have a Sony KDF-60XS955 tv. It won't power on,
I have that manual. There are three lights to the left of the power button. One is labled LAMP. The manual states "The projection lamp, which illuminates the picture, has a limited life. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the LCD projector TV flashes, it is time to replace the lamp with a new one (not supplied). Use a Sony XL-2200 replacement lamp (not supplied) for replacement. Use of any other lamp may damage the LCD projection TV." I also found in a different page " LAMP LED lights up in red when the lamp for the light source has burnt out." I guess burnt out would be extream. I found one other if you had opened the light bulb cover and didn't close it properly. " If the lamp cover is not reattached securely, the self-diagnostic function may be triggered and the POWER/STANDBY indicator flashes three times." You can down the sony manual at http://www.docs.sony.com/release/KDF60XS955.pdf
Jun 02, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
My sony kdf-60wf655 keeps shutting off on its own.what is the problem and can i fix it myself
If tv turns back on itself after shut down then it is weak lamp problem, replace lamp in tv to fix its problem.
Buy Sony original lamp for good picture in tv and replace it as it is user level repair and lamp replacement procedure is mentioned in related user manual.
If standby light start blinking after shut down, let me know how many times it blinks after three second pause to provide you info about possible cause of problem.
Thanks.
Dec 06, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My sony rear projection tv keeps shutting off and the power button keeps blinking red
You may have a lamp failure, you can remove the lamp probably located on side of tv, check your owners manual for location. With Sony the fequency of blinks can indicate the problem area. Potential of a fan failure if the lamp looks good.
Nov 27, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I need the instructions manual of the sony LCD TV 42"
Click Sony Support link to download instruction manual copy for KDF-E42A12U as model number is mentioned in question headings.
Thanks.
Nov 11, 2010 | Sony KDF-E42A12U 42" LCD TV
TV turns on for about 2 min and then shuts off for 30 sec.
Check the standby timer. Or reset your HDTV to factory settings. Just turn on the TV. While holding down the RESET button on the remote control, press the power button on the TV. (The TV will turn itself off, then turn back on again). Release the RESET button..
Nov 06, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Why power/stanby blinks light red
how many times does it flash? The back of the manual will usually tell you what the flashes mean. Try this: unplug tv from power. While unplugged, hold the power button in on the TV, not on the remote! Hold for 10 seconds. Replug the power and try to power it up. If you get no picture, you need a repair. Contact the manufacturer for an authorized servicer.
Jul 19, 2010 | Sony KDF-E42A10 42 in. LCD Television
The TV is frozen on one channel manual buttons not working nor re
hello here is how to reset your tv. turn on the tv while holding the reset button on the remote control,press the power button on the tv (the tv will turn itself off, then back on again) release the reset button. if this don't work get back to me and we'll try some think else good luck
regards
shaun
Jul 11, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Power keeps going on and off
Model number posted in question that is KDF-60SX955 shows it is Sony dlp tv, if tv shuts down and turns On itself then reason is weak lamp that is near to end of its working life and need to be replaced to fix this issue.
Lamp replacement procedure is written in user manual and its easy. Please buy Sony original lamp for good quality picture in tv.
Let me know if you have additional question.
Thanks.
Apr 18, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue blothes on LCD screen
Blue blotches spreading over the screen are failure of the optical block
contact Sony to see if you are eligable for a free repair.
Sony will cover the cost of the optical block repair (parts and labor) at no charge through December 31, 2008 for 2004 Model Year Grand WEGA™ Televisions with the blue spot problem.
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
http://esupport.sony.com/US/perl/news-item.pl?news_id=
Read more: Help from Sony for LCD rear projection with blue spots - Home Theater Forum - Home Theater Systems - HomeTheaterShack.com http://www.hometheatershack.com/forums/sony/5351-help-sony-lcd-rear-projection-blue-spots.html#ixzz0gm8a3718
Don't bedeterred by the dating of this announcement, it is a manufacturing fault and they have been pr5etty good to a lot of people with the same problem.
Please rate my help++++Thanks for using FIXYA
Feb 27, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand wega KDF-E50A10
unfortunately the B Box assembly needs to be changed in these and price of the part alone is more than half the cost of a new tv
Apr 10, 2008 | Sony KDF-E55A20 55 in. LCD Television
Televison & Video Logo
156 people viewed this question
Top Televison & Video Experts
Electro Med Services...
