Question about Sub-Zero Bottom Freezer Refrigerator
Ice maker stopped
We were out of town for a week and refrigerator was unopened for a week,
    Brigadier General:
  • 3,917 Answers
Hi
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Check to see if something has caused ice to back up around the mechanism—this can cause the fill tube to freeze, blocking the mechanism. When ice cubes are small and seem to be getting smaller, it generally indicates a frozen fill tube.
Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, unscrew the copper line from the back of the refrigerator, put the copper line in a bucket, turn on the valve, and see if pressurized water pours out.
Check the tap valve; a bad tap valve may cause the problem where the icemaker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can do this yourself, or call a repairperson or plumber to install an inline water filter when replacing the valve.
The water line attaches to a solenoid at the back of the refrigerator, and then travels to the icemaker. The solenoid may be defective or may not be receiving power. You can try removing the sediment screen inside the solenoid and flushing it with water to clean it; be sure to inspect any seals or diaphragms. Unplug the refrigerator first. Unless you're skilled at home repairs, this job is better left in the hands of an appliance repairperson.
As a rule, refrigerators are the most dependable of all large appliances. Even so, they do fail to do their jobs adequately on occasion, and when they do, the results can be disastrous because expensive food can spoil in a hurry.
Remember that the best way to lengthen the life of a refrigerator is to clean the condenser coils once a year or more frequently if they get dirty.
Let us know if you want to know something else accept the suggestion.
Thanks for contacting fixya.com
Posted on May 26, 2010
Our ED5SHAXM ice maker is intermitant. It will make ice for several weeks and then suddenly stop making ice, the water flow to the ice maker stopes and the bin empties it's final time. Then weeks later it...
Either the freezer temperature is too high or the internal thermostat inside the ice maker is faulty.
The freezer temp must be 5 degrees or less for the ice maker to work correctly.
If the freezer checks out OK you will need to replace the ice maker.
Apr 10, 2011 | Whirlpool ED5SHAXM Side by Side...
Ice maker stops making ice
the thermostat is playing up,,,thats the part that tells the frezer how cold it is and when to switch on or off!
but its not saying much right now!!! as its broken
Jul 03, 2010 | Maytag MCD2257 Side by Side Refrigerator
Ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
jkkjffkj
Jun 27, 2010 | LG LFX25960ST Stainless Steel French Door...
heatman101
98978yi
May 10, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Refrigerator/freezer just quit. Lights are still on
What has quit? The cooling of the refrigerator or the ice maker/ dispenser?
Jun 16, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Sub-Zero Bottom Freezer Refrigerator Logo
124 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
