Question about Dishwashers
My machine is 5 yrs old and has just stopped working. the wash light comes on but the wash cycle just does not start. The machine makes the normal start up noise but it appears that no water is going in or out. I have checked all pipes for blockages and there are none. Is the machine just at the end of it's lifespan?
    Sergeant:
  • 228 Answers
Sounds like water valve is open circuit cheap fix ,manually fill machine with water to check it will wash and drain ok if so get valve replaced you can do yourself not difficult to change.
Posted on May 27, 2010
Why my washing machine will start the wash cycle but will not spin or rinse?
the drain pump is probably blocked or overheating, when it starts beeping which lights are flashing reading from right to left e.g. 1,3,5 also what is the model number?
Aug 17, 2014 | Fisher and Paykel Washing Machines
F&P MW512 TopLoader washing Machine has no power
I would be having the capacitor for the motor checked as they do fry and not work
Jun 27, 2013 | Fisher and Paykel Washing Machines
Single mother of four wash machine not working only 2 yrs old.
Take off electricity wire, Open the filter from the front( maybee need to remove a rectangular cover.) turn the filter anti-clockwise. take out the hairneedle or coin. (the water will come out from the filter so make preparation with towels., see inside the filter if something is stucked around the small propellar. Turn the electricity back on. choose for example pumping program or centrifugeprogram. After that the machine should work.
Jun 01, 2013 | Whirlpool Washing Machines
"Pause" will not give way to the selected cycle
Turn off the machine then unplug it for at least 15 minutes and plug it back. Turn the washer on then press any button and wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously and the most recent error code will appear on the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the error code to determine the problem and necessary actions to be undertaken in order to address it. Include also the exact model number of the machine if the foregoing instructions don't seem to be applicable with your machine.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Oct 03, 2011 | Frigidaire ATF6000ES Front Load Washer
Kenmoore washing machine no longer spins during normal wash cycles
sounds like your spin cycle belt has come off or broken. it,s a simple fix at a repair shop.
May 02, 2009 | Washing Machines
Runs forever! even on Normal wash...help !!
Check to make sure you heating element has not failed. Dishwashers of today heat the water periodically through out the cycle and if the element has failed. The heating delay light is the indicator that tells you that it is trying to heat the water.
Feb 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Miele Dishwasher G2170 3 year old
On the display panel of the washing machine there are a few screws on the side. Remove that panel and check for power at the computer and sensor. Also make sure that when it is one and calling for water that it is getting everything everywhere
Feb 14, 2009 | Miele Advanta G2170SCSF Dishwasher
Machine just won't start
you have probably a bad lid switch
Dec 28, 2008 | Maytag LSE7806A Top Load Stacked...
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
60 people viewed this question
Top Dishwashers Experts
