Question about Hotpoint WMA31 Front Load Washer
My Hotpoint WMA31 will not drain - the smell is
My Hotpoint WMA31 will not drain - the smell is attrocious - what can I do please ? answer to: gill.will@yahoo.co.uk
  • 3 Answers
Check for blockage under cap bottom of washing machine
Posted on May 26, 2010
I have a hotpoint WMA31 washing machine. It has developed a fault. It stopped halfway through a wash cycle. I turned it off, drained it by switching to a short spin so the pump is working just fine. It...
hello graham the fault could be down to the module board the controls the motor speed. not sure where it's ;ocated on your model but the board usually sits at the back of the washer may wires coming off it hope it helps
regards
shaun
Oct 12, 2011 | Hotpoint WMA31 Front Load Washer
Wheres the filter on my hotpoint
Hi maizi42,
Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 11, 2011 | Hotpoint WMA31 Front Load Washer
My hotpoint aquarius wma31 washing machine won't drain any suggestions???
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 17, 2010 | Washing Machines
Can let me know how to go about changing the
hi joe i do these machines on a reg time almost every day.it easy to do the way you are doing it is the wrong way .so heres how to do just take top of the machine and put the belt on the small pully on the motor then half way round the drum wheel and turn it till its on make sure the belt is in middle of the pully if its not it will slip off i belive this is a hotpoint wma31 if belt keeeps comming off your bearings have gone it will need new bearing s good luck any more help just email me at marrathedolphin@hotmail.com
Mar 26, 2010 | Hotpoint WMA31 Front Load Washer
Will not drain and go into final spin , removed waste pipe and drained it manually , then ran another wash and same thing happened
Seems that your pump may need replacing. remove bottom panel at back of machine. You now have access to your pump. Using suitable screwdriver or grips remove retaining clips on pump pipes. Tilt Machine forward and unscrew 2 screws holding pump in position. Then remove 2 wires that go to pump. Ensure machine is unplugged. The pump is an Ask
Mar 11, 2010 | Hotpoint WMA31 Front Load Washer
Bad smell coming from washing machine
It probably is related to your drain outlet, depending on the set-up, I would suggest you remove drain hose and clean the place where the drain hose enters the drain system, if possible, clean all associated pipework
Please rate my solution.
Thanks.
Sep 17, 2009 | Hotpoint First Edition FEW10P Front Load...
Filter
take off rear bottom panel.
you will see a large diameter pipe going from bottom of machine to pump. take off this pipe at the machine end - careful, lots of water may come out.
filter is located inside this pipe. remove and clean
Aug 31, 2008 | Hotpoint WMA31 Front Load Washer
Dont understand what the programs do
my hotpoint aquarius wf540 lights keep flashing
Mar 01, 2008 | Hotpoint WMA31 Front Load Washer
Hotpoint WMA31 Front Load Washer Logo
195 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
