Question about Seagate Barracuda 7200.7 40 GB Hard Drive
I have an old st340014a hard drive which i would be using as a slave drive. all is ok when i first installed it on my computer. i noticed that it had 2 partitions as i saw it on "MY COMPUTER". i tried to delete that partition by inserting a WIN XP installer, which is succesfully done. but when i rebooted my pc, that drive was nowhere to be found. theres no icon anymore in "MY COMPUTER". but as i checked the device manager. it says that the device is working. the bios also detected it, but still i cant have an access to that particular drive what seems to be the problem??? need help ASAP.. thans.. god bless..
    Guru:
  • 266 Answers
Right click on my computer and go to manage.then click on disk management.
Then on right pane you will see your hard disk partition table..If you see something in black color or green color right click on that partition and select create new partition and create partition. once you create partition it will be in blue color,then you can go to my computer and see the partition you created there.
Posted on May 26, 2010
Testimonial: "thanks so much man... it was really a great help... hope u'll help more people out there.. god bless..."
Wont see slave Hard Drive in a Dell Dimension 2400
Did you set the Master harddrive as master?
Or is your reference that you set the jumper cap, on the jumper pins; of both harddrives to Cable Select?
What are the manufacturer names, and model numbers of the two harddrives?
If you just see something like - WD2500JB, that will work.
How many wire is the Flat IDE ribbon cable?
There are 40 wire versions, and 80 wire versions.
Notice I stated - Wire.
They will both have 39 socket holes that are used.
(40 socket holes, with 1 blocked off)
80 wire IDE ribbon cable has Master harddrive in middle.
Slave harddrive at end of cable.
Little weird, huh?
40 wire IDE ribbon cable, has Master harddrive at end of cable, Slave in middle.
As for, "Computer will not see it."
Not trying to insult your intelligence. Am trying to see if we are both on the same page.............
1) You go to My Computer, and there is no drive letter assigned to that harddrive you just installed?
If it is there, you double-click on it to open that harddrive.
Please post back in a Comment.
Regards,
joecoolvette
Mar 30, 2013 | Dell Dimension 8400 PC Desktop
How to slave the hard drive
You must go to BIOS setup and follow the steps.God bless youHowever follow this steps:
Instructions
Remove the screws on your computer case and slide the cover off of the machine. Notice the hard drive bays in the front of the machine. The existing hard drive is installed in one of these bays.
Use the tweezers to set the jumper pins to "Slave" mode. The jumper pins are white connectors located on the back of the hard drive. Above the jumper pin section on the hard drive is the schema to set the drive to "Slave."
Insert the hard drive into the computer case bay underneath the existing drive. Screw in the drive and mount it to the case using the screws included with the hard drive packaging.
Connect the hard drive cable from the main hard drive to the secondary slave drive. There are two connectors on the hard drive cable. The very end of it is inserted into the main hard drive. The middle connection is used for the slave drive. Insert this secondary, middle connector into your newly installed drive.
5
Insert one of the power supply cables into the back of the hard drive. This supplies electrical power to the device.
6
Replace the case cover back onto the machine. Ensure you replace the screws to properly fasten it to the computer case.
Jan 23, 2013 | HEWLETT-PACKARD 500B MT E5700 3202GB 27 PC...
How can I attach a Samsung hard disk HD080HJ/P to a Dell Optiplex 755 Core 2 Duo E4400 PC computer? There seems to be no master/slave settings on the hard drive.
Newer sata drives do not rely on the master/slave settings that old IDE drives used. Remove the old drive from the bad computer and plug it into an available slot in the new computer. Boot the new computer. Under My Computer/Computer the second drive will show up with the next letter available. Alternately you can buy an external hard drive dock that connects via usb and use that to transfer your files.
Dec 01, 2012 | Samsung (HD080HJ/P) 80 GB SATA Hard Drive
I pulled the seagate 2.5"
When you use external adapters to plug drives into USB ports the drive needs to be set for mast not slave. The internal drive is one one channel and external drive is on a different channel so neither drive is a slave, both are masters with not slave drive present. Try removing the jumper you installed and try the drive, it should be seen because all windows XP or later do not need drivers for USB drives.
I hope this helps, if so please rate my solution.
BuddyMc
May 06, 2011 | Seagate Momentus 4200.2 100 GB Hard Drive
Take Three: I have an older Maxtor Hard DriveTake Two: I have an older Maxtor Hard Drive (Model 90645D3). I need to transfer some files from it (Win98SE) to new hard drive (WinXP Pro). I asked earlier and...
Jumper off will set the drive to slave. If you can connect both drives to the same ribbon cable with the master on the end & the slave to the second connector. Look at your bios as win is booting up to see if shows the drive as slave, you will not be able to copy windows as a operating system off of the drive, but should be able to copy files.
Good luck on your endevors.
Lee
Nov 12, 2009 | Maxtor Hard Drive
Install old maxtor HD on newer pc, change it from mster to slave
From your own description Slave : Off therefore remove the jumpers
Jul 26, 2009 | Computers & Internet
Installing old maxtor HD on newr pc, have to change it to a slave
J50 is the one furthest from the power connector. To make it a slave remove ALL of the jumpers.
Jul 26, 2009 | Maxtor Hard Drive
HP Compac NX5000 wont load XP Home on new hard drive
This situation leads me to believe that the CD or DVD drive is faulty,,or the install disc you are using is scratched or dirty.
Try cleaning the disc and begin again.
Another option is to take the hard drive out and using a 2.5 to 3.5 inch HD adapter ,,plug into a desktop PC as a slave.
And copy your WinXp cd onto a partition on your laptop HD.
Then using a Win98Se floppy boot disc you can access the winXP and install from there.
Nov 12, 2008 | HP Compaq nx5000 Notebook
Old hard drive new computer
I would suggest not even connecting the old drive to this computer. The stats on your new computer are pretty proficient for everyday personal use. I wouldn't use it has a slave drive considering it is pretty small and probably pretty old. You'd have to get some different adaptors to connect your 39 pin drive. Sorry if this isn't what you want to hear. I'm just a college student and this is what I'd do.
May 12, 2008 | Computers & Internet
Seagate Barracuda 7200.7 40 GB Hard Drive Logo
209 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
