Question about Kenmore 24 in. 16039 Built-in Dishwasher
No power at control panel on dishwasher
We lost power to the house while the dishwasher was running. Now the dishwasher will not start. Circuit breaker did not trip but we did try restting just incase.
What ended up being the problem? i am having the same issue now.
Posted on Oct 27, 2010
  • brick66 Sep 02, 2011
    me too- no answers though?
Maytag dishwasher no lights and left water in pan
I am a homeowner. I do have a maytag dishwasher as well. It may be a control panel problem. You will have to expose/remove/examine the control panel circuit board by removing the top six screws on the door. (I don't think you have to remove all of the screws: just the ones securing the control panel to your door. On my dishwasher the screws are: one on each side of the latch (so 2 screws here), then one one each top corner (so 2 total screws at corners), and finally one screw along each side edge : altogether 6 screws. To expose the inside you will have to remove covers that are secured by tabs. Upon examining my circuit board I found a disgusting nest of cockroach eggs, waste products that probably corroded my board and ribbon cable. Apparently the cockroaches love the warmth of this area. So if you have cockroaches in your house this may be the cause of your problem. I replaced the circuit board and now my dishwasher runs just fine. (I had different dishwasher symptoms but still it may be a circuit board problem)
Nov 08, 2017 | Maytag Dishwashers
Reset figidaire dishwasher. Control panel not working.
hi david.
not sure if this link will help you out but have a look.
how to Reset figidaire dishwasher Google Search
Nov 01, 2017 | Dishwashers
How can I start my dishwasher?
door switch out of adjustment, must close micro switch to run
Jul 07, 2014 | GE Dishwashers
How do I reset the control panel on my dishwasher?
could be wites in the door at the hinge, the microswitches in the door lick assembly, or if it is a series of flashes it could mean a code depending on your model number. Last to check is visuals on the control board for burning, or any loose wiring.
Jun 18, 2014 | Maytag Dishwasher
Model w10311121b no power
Hi Scott. It appears you have the same dishwasher as mine bought in 2010- it worked sporadically for several years. I bought one year warranty ($289) in Feb2014 . Over 2 months, service technicians replaced 3 parts (user control board, motor control board and water sensor) hoping that each would fix it. They told me to run hot water before starting a wash cycle. Dish washing cycle failures were still sporadic and it finally lost all power in May2014. Service techs would not come out so I confirmed house power supply with a multimeter and then took the door apart to access the latch. I determined the latch kill circuit was not assembled properly and it had carbon buildup which I scraped off.
If your warranty has ended and you attempt this, do not use a power screw driver with these Torx screws as you can easily strip the threads or damage the plastic user control housing by screwing in too far on the top screws. (especially if you forget to reinstall the internal handle which acts as a spacer).
To disassemble: Remove the top 4 screws and top side screws, loosen the middle and lower side screws as needed. Separate the washer door face wide enough to remove the user control board, let it hang by the cord. The handle will be loose in the way, remove it. The latch has a white plastic kill circuit which is held to the latch with tabs. Unplug the circuit and carefully remove it. The circuit comprises 2 flat metal sheets that are pushed together by the latch lever when the door is shut. These plates separate when the door is open to kill washer power. The latch lever should be under both circuit plates with the shorter plate on the bottom. (long plate, short plate, lever, white housing). Reassemble, remember to include the handle My dishwasher operates properly now.
Apr 19, 2014 | KitchenAid Dishwashers
I have a ge profile dishwasher model pdw9280j00ss. After a storm event, house lost power. Since that time, dishwasher constantly beeps; however has no power to it. shut off circuit, beeping stops; but...
http://www.geappliances.com/search/fast/infobase/10000380.htm
According to this link, it should reset after the power is shut off for awhile. Maybe try holding the start/reset button too. Also check the circuit breaker or any fuses
Aug 28, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
We have Frigidaire 24 in. FDB1050REC dishwasher. The control panel has no power; no lights and nothing works. This problem started after a power outage. All circuit breakers in house ok and other outlets...
more than likely fuse is gone in plug. take dish washer out. change fuse in plug. if it doesnt work get extension lead and run it from a socket that definatly does work and plug washer into that. if nothing then its internal.
Jan 16, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
No power to dishwasher
Do the following:
  1. Check the power from the wall outlet or the branch circuit itself.
  2. Check for a blown fuse or a tripped circuit breaker.
  3. Check the wiring connections of the dishwasher from the house wiring.
  4. Check the door switch. Remove the control panel cover or the interior liner of the door whenever it is applicable. Replace if defective.
  5. Check the timer or selector switch. replace if defective.
Aug 30, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher won't start
If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Wiring
Timer or selector switch
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
May 30, 2009 | GE Nautilus 24" Built-in Dishwasher
Kenmore 24 in. 16039 Built-in Dishwasher Logo
187 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
