Question about Epson Stylus Photo R300 InkJet Printer
My Epson Stylus D78 printer...
Help
i have university work to do and cannot print any work. for the last 3 days it has just not printed. turns on but does not print. documents say pending.
went on diagnose problem and told me to remove application from my pc. i have done that but only to discover i no longer have the Cd to run through it to re install it.
what can i do? please help me ASAP please x
    Problem Solver:
  • 6 Answers
Hi, Go to the Epson web site and enter your product i.e. Epson D78 ect. from the dropdown list.When the next page appeares go to Software. The page after that will highlight YOUR printer software and driver.Download this to your desktop then install.Reboot your pc and turn your printer ON. This should do the trick. Good luck!
Posted on Apr 07, 2008
I replaced the cartridges on my epson d78 clour printer today. The printer acknowledges are all full, yet the printer is printing out totally different colours on the paper to the ones visible on the...
Hi.
I spent a while at the Epson site, searching for a printer with the designation you gave us - d78 - and found nothing resembling that. So, here is the link to Epson's support section. Hopefully you can find the printer there, and get the help you really need for it.
My advice is to stop printing now, so as to not use up all of your ink doing test after test, since none of the tests are giving you anything but the wrong solutions.
Here is the link:
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes&oid=-10222&infoType=Overview
I do hope this helps get your printer back on track and printing as it should do.
Cheers!
-a.
Nov 05, 2010 | Office Equipment & Supplies
Replaced the ink cartridge now it will not print
*** I'll be more than happy to help you on that.
there is a great possibility that the nozzles of your printer are clogged by dried inks.maybe cause by the previous inks that you just replaced. we can check that by printing a nozzle check pattern.
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX110 Series. 3. Hold down the nx110_tx110_ug.1.98.1.jpg Stop button as you press the nx110_tx110_ug.1.98.2.jpg On button to turn the Epson Stylus NX110 Series back on. When the nx110_tx110_ug.1.98.3.jpg On light begins to flash, release the nx110_tx110_ug.1.98.4.jpg Stop button. nx110_tx110_ug.1.98.5.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx110_tx110_ug.1.98.6.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Using the Control Panel 1. Load a few sheets of plain paper in the sheet feeder. 2. Make sure the Epson Stylus NX110 Series is on and the ink light is off. 3. Hold down the nx110_tx110_ug.1.99.1.jpg Stop button for three seconds to start the cleaning cycle, which lasts around one minute. The nx110_tx110_ug.1.99.2.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus NX110 Series during a cleaning cycle or you may damage it. 4. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 4 times. You can also turn off the Epson Stylus NX110 Series and wait at least 6 hours. Then try printing again.
Feb 16, 2010 | Epson Stylus NX115 All-In-One InkJet...
PLSE HELP IM TRYING TO PRINT BUT NOTHINGS HAPPENING, IT IS ALL SET UP
test the printer first, so that we can isolate the issue. print a nozzle check to eliminate the possibility that the nozzles are clogged by dried inks. if nozzle check prints blank page or it printedr but w/ gaps or breaks, do head cleaning
Check the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus CX4400 Series. 3. Hold down the cx4400_ug.1.79.1.jpg Stop button as you press the cx4400_ug.1.79.2.jpg On button to turn the Epson Stylus CX4400 Series back on. Hold down both buttons until the cx4400_ug.1.79.3.jpg On light begins to flash, then release the buttons. cx4400_ug.1.79.4.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. cx4400_ug.1.79.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Clean the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Hold down the cx4400_ug.1.80.1.jpg Stop button for at least 4 seconds to start the cleaning cycle, which lasts around 1 minute. cx4400_ug.1.80.2.jpg The cx4400_ug.1.80.3.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus CX4400 Series during a cleaning cycle or you may damage it. 3. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 2 times. You can also turn the Epson Stylus CX4400 Series off and wait at least 6 hours. Then try printing again.
Feb 15, 2010 | Epson Stylus DX4450 All-In-One InkJet...
My printer wont respond or print
Did you open it up and look for paper jammed in it, or maybe it mispulled and just needs to be reset. Inkjets are fairly simple.
Mar 23, 2009 | Epson Stylus Photo R300 InkJet Printer
Cx6600 printer problem
if you left your printer for two weeks or more without using, the print heads may be stuffiness. In this case (aparently yours cases) you must take your printer to a authorized service, they will can clean (with a proper fluid) or replace the ink heads, if cleaning is not possible.
Mar 16, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Printer driver fir epson stylus D78
Did you try to search on the web site like google... If not try putting your pinter name and number(epson pinters stylus D78+drivers)...... And try to down load them
Mar 05, 2008 | Computers & Internet
Epson Stylus Photo R300 InkJet Printer Logo
277 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
