Question about Skil Saws
I have a 10 in miter saw, and when you plug it in it starts to run and then blows the fuse
    Problem Solver:
  • 6 Answers
Check the name tag. The voltage and amperage are both listed there. It sounds aa though it draws too much for you (probably 15 amp) circuit. Have an electrician install a heavier amperage circuit, or return the miter saw and find one that draws a lower amperage.
Posted on May 26, 2010
When I try to start the saw, it bumps but does not start. The brushes look good.
clean the brushes holder unit and fit the car ban brushes check car ban brushes is content to armature and also check power cord and fuse.
Oct 11, 2014 | Hitachi C10FCH2 10 Inch Miter Saw With...
The blade brake is not working on my miter saw.
Clean your saw ! Use your air compressor with an attachment to get back in the nooks & crannies, blowing all the caked up sawdust out.
Oct 09, 2014 | Skil 10-in 15-Amp Compound Miter Saw...
I have a Malita dual sliding compound miter saw LS1016LX. Trigger will not start saw after 5-10 cuts. When saw sits for 30 minutes, it runs again.
I'd contact a Makita dealer. I've had this saw for years without a single misfire on the trigger. Could be heat related, but that's a stretch. Here's their contact information:
Makita Contact Us
Oct 07, 2014 | Makita 10" Dual Bevel Sliding Compound...
The only way to turn the saw off is to unplug it. Ryobi 10 inch sliding compound miter saw model TSS100L
You may be able to take the handle apart and, using compressed air, blow any sawdust out of the handle and switch but most likely you'll have to replace the switch.
Feb 14, 2014 | Makita 10" Miter Saw LS1030N
Mitre saw running, but not switched on?
there should be no power going anywhere until you pull on the trigger. With that in mind I would be looking at the switch for the fault
Dec 02, 2012 | Ryobi 10 In Miter Saw With Laser
How do you "unlock" the Delta miter saw?
To unlock a miter saw, push down on the saw to unlock the head and loosen the knob on the table to make adjustments. Start using a miter saw with help from a custom furniture maker in this free video on woodworking tools. Read more: How to Unlock a Miter Saw How to Unlock Miter Saw Best Miter Saw Reviews Real Man Miter Saw
Oct 22, 2011 | Delta SM100M 13 Amp 10" Compound Miter Saw
My 10" Bosch miter saw
I would remove the blade and try the saw again, there is a possibility that you might have gotten a flange on incorrectly or left the spacer out.
Sep 10, 2011 | Bosch 10" Slide Miter Saw
Changing the blase on a craftsman miter saw, model nimber 315.212240
my miter saw has stopped working. i have checked the plug and electrical connection. it worked without problems 2 days ago. it gave no warning of problems. is there "a built in" fuse or circuit breaker?
Oct 07, 2010 | Craftsman 12 In Miter Saw With Laser Trac...
Saw runs continuously
The on off switch has a contact that has probably fused together from making and breaking causing an arc. You may try giving it a good 'wrap' with the back of a screw driver to free it, or replace the switch.
Jul 15, 2009 | Hitachi C10FCE2 10" Compound Miter Saw
Miter saw motor is running back wards
I'd say it was the new wiring that was reversed. Motors cant really start reversing themselves on their own and the only other way it would seem reversed is if the blade was put on backwards...
So yes I think you have the wires reversed when you re-wired the cord.
Please rate this solution on FixYa!
Jun 21, 2009 | Milwaukee Tool 10" Magnum Compound Miter...
Saws Logo
313 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
