Question about Carrier 38CKC036 Air Conditioner
Whistle noise from the air handler - Carrier 38CKC036 Air Conditioner
  • 391 Answers
Check the filter and change if dirty or restricted. Make sure the blower access panel is secured. Make sure the cooling coil is clean on the top (outside) and on the bottom (inside).
Posted on May 27, 2010
2 Suggested Answers
  • 34 Answers
SOURCE: air handler fan appears to cause thumping noise
If it's a belt drive check the belt or the pulley could be worn. If it's direct drive check to se if something is in the fan wheel causing it to be out of balance.
Posted on Sep 11, 2009
Whistling sound from auto ac ducts
The whistling could be an indication of lack of air flow which will cause the evap coil to frost. The frosting could also be an indication of low refrigerant. As a quick & dirty test, here's something to try. After the system has been off long enough for the coil to completely thaw, set the thermostat for "fan on" & open the door to the air handler (or furnace). If you have to pull hard to get it off & air rushes in thru the door opening, you probably have a return air problem.
Read more: http://www.doityourself.com/forum/air-conditioning-cooling-systems/219207-whistling-noise.html#ixzz2xZOyZr5b
Mar 31, 2014 | 2004 Toyota Corolla
We have recently purchased a new home and the UBHK-25J21SFA air handler makes a whistling little tune and then the heat comes on. Never fails to work but noise is annoying.
Make sure the air is balanced... air handlers are rated @ a certain design static pressure. The static rating is on the air handler tag. Have someone measure that static. Too often hvac installers don't know much about airflow & they will undersize ductwork. Then again it could just be a dirty coil.
Nov 27, 2013 | Heating & Cooling
Ford explorer making whistling noise at air filter
a whistling noise, in itself, IS the vacuum leak, the leak is in between the filter and intake. because when you put in a filter, it causes air resistance and the air is pulling in from a small area (causing a whistling) ONLY use carb cleaner to check for leaks.
Starting fluid may cause internal detonation that may damage the engine.
(small to medium amounts) of water would cause hydrolock causing major damage.
May 05, 2012 | Ford Explorer Cars & Trucks
What supply house sells haier air handlers in Atlanta ga
any 4 tonnes air handler will fit if you respect de gas for the unit if r22 than than r 22 air handler if r410 than r410 air handler you can put r410 air handler if r 22 not avalable but be sure that expension valve is compatible.
Dec 13, 2010 | Haier HC48C1VAR Central Air Conditioner
Whistling noise while driving
If it is whistling while you rev your engine (while parked), then most likely there is a leak or hole in your air intake or vacuum hoses.
Facts:
1. Your car creates a vacuum to constantly receive air from the outside.
2. A whistling noise is created when air travels through a hole.
Check all air pressurized ducts for holes or leaks.
Check air intake system for holes or leaks.
Jan 08, 2010 | 2000 GMC Jimmy
Air handler fan appears to cause thumping noise
Sep 11, 2009 | Heating & Cooling
Whistle Noise
Check your air intake manifold hose if is crack this cause whistle noise replace the hose.
Feb 02, 2009 | 1996 Toyota Previa
Loud whistle noise kelvinator split KSR25F-01
It may be the small vent fan motor on the inside if the control panel. When the noise begins remove the panel and you may be able to catch it in the act.
Dec 27, 2007 | Carrier 36KCARMS Air Conditioner
LG Electric Front Load Dryer door whistles!
under warrenty call serv tech they ussally know whats wrong from svc bullitans
Dec 22, 2007 | LG DLE2532W Electric Dryer
Carrier 38CKC036 Air Conditioner Logo
502 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
