Question about Toshiba Satellite A45-S120 Notebook
My hard drive is bad - It had windows xp home edition - I want to replace my hard drive and load xp home back on it. it was a 60gb 4200rpm travelstar drive - what can i replace it with?
    President:
  • 2,653 Answers
Any ide 2.5 laptop hard drive will work.
the IDE is the important part, it's the older style. Don't get SATA.
The size of the drive doesn't matter.
Hope this info helps.
Posted on May 26, 2010
What is the password for hitachi HTS545025B9A hard drive
The password is your responsibility. If you forgot that's a bad mistake, or if it's belongs to someone else ask them.
Jun 23, 2014 | Hitachi Travelstar 5K100 HTS541060G9SA00...
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
Sata drivers for win xp
If you use a XP SP3 install CD it should include the sata driver.
Sep 14, 2012 | Hitachi Travelstar 5K100 HTS541060G9SA00...
My computer has no problem booting up from the C:/ Drive, but when I try booting with a CD from the A:/ Drive (Windows XP Home Edition), it does not find any hard disk drives installed in my computer. ...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Dec 12, 2010 | Hitachi Travelstar 5K100 HTS541060G9SA00...
WINDOW NOT INSTALL
Take your computer to a qualified technician.
She/he can solve your problem, when you give more details about the problem(s) that you are experiencing.
May 31, 2009 | Hitachi IBM HARD DRIVE 20GB 2 5"...
Hitachi Travelstar 60GB hard drive makes noise only after connecting to internet
A clicking hard drive noise is a sign of a hard drive thay is not long for this world. Make sure you backup your data periodly before it fails completely.
Apr 28, 2009 | Computers & Internet
Running out of space on C drive
hi, its possible to merge two partitions.
down load a partition changing software like partition magic and install it. Have a look at the help available and and go for merge partition.
thank you
Aug 15, 2008 | Microsoft Windows XP Home Edition
Lost Master Harddrive Password
First chek in BIOS if exsist CHANGE HDD PASSWORD if not use download somwhere HIREN BOOT CD v8.2.Let me know if u got help;)
Oct 10, 2007 | IBM TravelStar 40GN 40 GB Hard Drive
Compact Flash 802.11b card?
just a guse but the batery looks to have enouth mA to run a CF 802.11b card and an sd blue touth card i think if you will be connected to a network or a wifi connection i would invest the money in the 3400MAH insted of the 1440MAH.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Toshiba Satellite A45-S120 Notebook Logo
119 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
