Question about Acer AL1914 19" LCD Monitor
I have an Acer AL 1914 Monitor. Green light
I have an Acer AL 1914 Monitor. Green light (power button) comes on but no picture-black blank screen
  • 11,361 Answers
Check power supply section for bad caps first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 26, 2010
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
LCD Screen blank
The picture board on your monitor is bad, since the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 25, 2010 | Acer AL2416WBSD 24" Monitor
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Acer AL1914 black screen, green light
it sounds like a deleted driver? try getting the driver for the monitor, did you loose the Operating system at some point, if so try a system restore to a date when the computer was working properlly prior to the malfunction. It sounds like it restored you to a time before the driver for that monitor was installed.
Feb 16, 2009 | Acer AL1914B Black 19 in LCD Monitor
Acer 20" LCD AL2017 does not give a picture @ all.
You can look on eBay for BACKLIGHT FLUORESCENT BULB for your model.
They're around $20.00.
Dec 25, 2008 | Acer AL2032WD 20" Flat Panel LCD Monitor
LCD Monitor wount turn on Black screen
my Acer AL1716 monitor will not come on after pressing the on button and no green light.
Aug 25, 2008 | Acer AL1716B 17" LCD Monitor
Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Aug 22, 2008 | Acer AL1714 17" LCD Monitor
Blank Screen..Will not power off
The flash light test only works with lcd monitor as they have back lights. Double check the connections again, also, if you can borrow a monitor try it on your pc, it may be your graphics driver needs to be uninstalled and re-installed, but you will need a monitor to see.
Dec 13, 2006 | Proview PS 776 Monitor
Acer AL1914 19" LCD Monitor Logo
294 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
