Question about Elna Sewing Machines
The clutch for my Elna air electronic sewing machine appears to be broken...anyone have any idea about how much it may end up costing to fix?
  • 155 Answers
SOURCE: I need to thread an
Needle Faces Where?
I Need to Tighten the Tension....
Changing a Needle
Need Help
Basic Questions-
Bobbin Assembly Popped Out!
Do You Think My Machine is Fixable?
How to Change a Broken Needle
Needle Bar Adjustment
Oiling an Elna 3007
Getting the Timing Belt Off?
What Size Needles for My Machine?
How to Oil my Machine?
Where to Oil??
Stitch Length Knob Woes
Can't Seem to Put the Bobbin in Correctly
Timing Belt Tension
Adjustments
Running Very Slow-
Oiling Points on Singer 257
Oiling My Singer Touch & Sew
Singer 457
Featherweight Case Odor
Brother XL2010 Q's
Does My Machine Have More Than One Belt?
Cannot Seem To Adjust the Tension
What to Do About a Gumming Up Needle
How Tighten My Bobbin Tension, Please
Is it Covered Under Warranty?
Proper Threading Instructions?
Just a Foot Pedal?
Simple Threading Instructions for a 1036
Threading a Singer 600
Replacing a Blade on a Johnson Ruffler
Changing the Needle
Lubricating a Singer 1036
Thread Balling Underneath
Warranty Info
Machine Covered in Hardened Oil
Spindle Stuck?
Do Motors Die?
Singer 457
Brother Sewing Machine
Servicing My Machine-
Belt Replacement
Lubricating My Sewing Machine
check out this thanks.
Posted on Oct 26, 2008
SOURCE: Need parts for Elna SU Air Electric sewing machine
My Elna repair man is also the individual I purchased my Elna from in December 1980. His name is Boyd Albright, located in Ottawa, Kansas. I have never had the issues you describe, but Boyd has always serviced my machine and as far as I'm concerend, is the best. When I was told by another sewing machine shop in Mississipi that my machine could not be fixed, Boyd did and for less than $40.00! Contact info: 1231 S Willow St
Ottawa, KS 66067-3439
(785) 242-4340
He works out of his home as he is semi-retired.
Posted on Aug 17, 2009
  • 1116 Answers
SOURCE: Can anyone tell me if the Elna 3007 sewing machine
Mechanical.
Here is an overview - http://www.oksewingandvacuum.com/3007.htm
Posted on Apr 03, 2010
Testimonial: "Thank you so much. It is mechanical, as I thought not computerized. There is going to be a very disappointed buyer on ebay!!!!"
Tally Girl
  • 1133 Answers
SOURCE: how to thread the bobin on a elna air electronic
I assume you mean when you wind a bobbin full of thread??
You take the end of thread from your spool through the tension device or an eyelet on top of the machine, then back to the bobbin on the bobbin winder and thread the loose end through a top hole on the bobbin. Click the bobbin in against the stop and press on the pressure foot to start to wind. Hold the top thread for a bit as the bobbin starts to fill and then once it has been covered by a row or two of thread, stop and cut of the loose end from top of the bobbin. Now continue to wind the bobbin until it cuts out as it fills against the stopper. Nudge the thread with a finger tip as it spools onto the bobbin to help get the bobbin filled top and bottom and not just in the middle. (bit like when you coil the garden hose onto the reel, it always wants to go in the middile only and then jams up LOL).
Also a really good idea to place your scissors handle into the top of the thread spool to slow/control it as the thread reels off it. This helps give an even tension on the thread going onto the bobbin which really helps with stitch quality later.
Posted on Mar 03, 2011
Tally Girl
  • 1133 Answers
SOURCE: Elna Carine Electronic Sewing Machine
You should be able to buy a manual online but it may be a cd or image pdf file. Try www.sewingpartsonline.com or www.sewusa.com. If they don't have the Carina but have the Air Electronic SU, model 68 then this will be almost the same. Main difference is the Carina has the needle up/down button.
Here is threading up images to get you started.
Posted on Sep 28, 2011
How to fix zig-zag function on elna stella TSP Air Electronic
please see my previous response on this problem here
http://www.fixya.com/support/t12545813-elna_tsp_air_electronic_58_will_not_zig
its usually due to either gummed up needle swing bar or a broken spring internally.
Aug 13, 2017 | Elna Sewing Machines
Have inherited my mom's elna Stella tsp air electronic. The foot control became harder to press, then stopped working. Elna want ZAR858 for a new part! Can I repair it?
Im confused, Stella TSP air electronic has a round black and white air foot with a black air line to the side of the machine like this.
or the earlier Lotus TSP has a electric foot and cable which is made of older style plastics, these are harder to find now but Sewingpartsonline.com carry an aftermarket one like this
No, not cheap parts but beautiful machines that with TLC work so well.
Mar 23, 2013 | Elna Sewing Machines
ELNA Clutch slip. I have an Elna SU 68 which has served me very well over the years. Recently the clutch has started slipping after about 20 mins sewing. I have stripped and cleaned the pulley and...
Hi Dave,
not sure where you are located for a repairer but the US Swiss Elna Guru is White Sewing Center for spares and repairs.
But I would strongly suggest that you jump over to Yahoo groups and join the group called "Elna heirlooms", then search the threads there as there has been lots of discussions in the past on the Air Electronic drive belts, I can't remember now what the fix is but there are some really talented mechanics in that group, Jim is one who springs to mind.
Also, these machines do have have capacitors inside the air electronic panel for controlling the speed. Also, in this group there is some shared images of manuals/parts/repairs which should be of help to you.
Jun 01, 2012 | Elna Sewing Machines
WHERE CAN I GET AMANUAL FOR ELNA AIR ELECTRONIC TYPE 57.ALSO THE AIR FOOT PUMP DOES NOT WORK PROPERLY. ANY IDEAS
You can get parts on line at sewingpartsonline.com. But if you are in USA then White Sewing Center is the guru for all Swiss Elna parts. The air foot is just a air bulb and line so first check it for split or holes, often the chair leg may catch it. Great machine to own, I have 2!
May 14, 2012 | Elna Sewing Machines
Elna 8200 embroidery machine. Broken needle
Computerized machines need to be serviced by an authorized sewing machine technician, preferably Elna.
Diving into this may cause more problems and end up costing you more money for repair.
Mar 13, 2010 | Sewing Machines
My elna SU air electronic model 68 is not working I need to fix it. How can I find a repair expert.
I have a Elna air electronic No 69 I am having trouble with the tension . How can I fix this.
Jul 13, 2009 | Elna Sewing Machines
Sewing Machines Logo
50 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
