Question about HP LaserJet 3390 All-in-One Multifunction Printer
No paper pickup on hp 3390 printer - HP LaserJet 3390 All-in-One Multifunction Printer
  • 54 Answers
SOURCE: ** Paper Pickup
Check the paper pickup tray & roller may be its not working. If possible contact the local vendor for printer servicing.
Posted on Mar 10, 2008
  • 54 Answers
SOURCE: No Paper Pickup error
Check all this ---------
1.check the paper pickup roller may be its not functioning
proper.
2.check the paper pickup sensor(clean this)
3.check the paper pickup tray for proper work.
4.check the gear of paper pickup.
thanks
Posted on Mar 21, 2008
  • 35 Answers
SOURCE: HP Laserjet 3050 No paper pickup
NOTE:
If the printer DOES NOT PICKUP paper .
That is a jam also so the places to look are smoth rollers or smoth spots on the rollers.
trays not adjusted properly and if they have it some trays have a coustom/standarsd switch (should be in standard for letter/legal paper
Posted on Jun 13, 2008
  • 56 Answers
SOURCE: HP Laserjet 1320 Series Printer-Grinding Noise Won't Pickup Paper
take the roller out again but this time make sure the paper sensor is in the proper place. it does go scew when putting a new roller in. It happened to me last month.
you dont need to get another printer.
Posted on Oct 09, 2009
  • 313 Answers
SOURCE: When printing from an HP Laserjet 3390 all in one
if it is uniform, replace the cartridge
if it is not uniform, you have to replace the fuser asembly
Posted on Mar 17, 2010
Hi, I am trying to print with my HP LaserJet 3390 and it says 'No paper pickup'. Can you help? Regards, Peter G.
Try to perform the following steps in the mentioned order:
1. Verify that the media was inserted far enough into the input tray. In tray 2 (HP LaserJet 3390/3392 all-in-one), verify that the paper-length guide is in the correct position for the media size that you are using.
2. Reload the media in the input tray and press c00597632.gif to continue the job.
May 23, 2011 | HP LaserJet 3390 Printer
Not pickup for try 2 paper
check and make sure paper stop at back of tray is set to letter also check roller making sure right side plastic not broken
Jul 30, 2010 | HP LaserJet 3390 All-in-One Multifunction...
When printing from an HP Laserjet 3390 all in one printer, getting a thick black line down one side of the paper.
Mar 16, 2010 | HP LaserJet 3390 All-In-One Printer
Error message for 3390 printer: No paper pick-up
Its probly giving you the 13.1 error which means that there is a paper jam. But theres probably not. The printer just thinks that there is one. Replace the pick up rollers and everything will work fine.
Jul 14, 2009 | HP LaserJet 3390 All-in-One Multifunction...
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Paper jamming behind the toner cartridg every time i print
Open the rear door and check for jammed paper between the fuser and exit assembly. You will need a flashlight
Mar 12, 2009 | HP LaserJet 3390 All-in-One Multifunction...
HP Laserjet 3390 Prints a Black Line on papers
make sure you check and make certain there are no scratches clean both the top of the scanner and the scanner bed itself and wipe down with a lint free cloth
Feb 12, 2009 | HP LaserJet 3390 All-in-One Multifunction...
proper.
thanks
Mar 20, 2008 | HP LaserJet 3390 All-in-One Multifunction...
** Paper Pickup
Mar 09, 2008 | HP LaserJet 3390 All-in-One Multifunction...
HP LaserJet 3390 All-in-One Multifunction Printer Logo
897 people viewed this question
Seeker5211
Seeker5211
