Question about KLH R5100 Receiver
No Sound The turner works but no sound comes out sometimes it works and sometimes it doesn't
    President:
  • 1,099 Answers
check if the speakers connected to the receiver is okay with use of an ohmmeter to read if it faulty.
Also check if an earphone is connected to the mic jack of the receiver because this may seize the output that will go into the speaker. if otherwise the audio transistor of the receiver is bad replace with the same type of value.
Good luck....
Posted on May 26, 2010
Chat live
1) you must the headphones in any radio, for to see if the problem they are.
2) if they are o.k go control panel use the utility system restore put the last date that you know that was working.
God bless you
Jul 25, 2013 | Sony VAIO Computers & Internet
Sound doesn't work under linux
We'd need to know what computer you're using to be able to help here, Linux sometimes needs specific drivers (and sometimes has no available driver at all) for devices to function.
The best bet is to look up what sound device your using, like a sound card, or what motherboard your computer has, and do a google search for that device and "linux driver".
You should find what you're looking for, if it exists, when you do that.
Dec 21, 2012 | Red Hat Enterprise Linux ES 3 Standard...
What do i need to make the built in tv work
Hi anker, you'll need a mb tv turner installed in the vehicle and your dealer or someone with the star diagnostic computer to unlock the tv feature for you. I've done it on a few s class before. Now that tv in the usa is digital, the analog tv turners doesn't really work here anymore however with a few modification you can hook a dvd player up to your command system.
Please take the time to rate my answer. Thank you.
Jun 16, 2011 | 2000 Mercedes-Benz S-Class
Heater doesn,t work. Controls on dash sometimes light up & sometimes doesn,t. All of my fuses are good. It seems to act up mostly in the morning. Sometimes if I turn my head lights on my gauges quit...
Morning Charlie,
If it were me, I would check the wires coming & going to & from engine. Maybe something is crossed. That's what it sounds like, anyways.
Oct 08, 2010 | 1996 Jeep Cherokee
I recently purchased a Philips SAA7130 tv turner card and installed evrything but they is no sound coming out
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} An [5003:0x8004ase8] has occurred running the setup
Jul 25, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
My ice maker pushes out ice into container but the turner has just broken that pushes ice out into glass and is making a beeping sound every couple of minutes. what is the beeping sound mean or is it just...
Sounds like the gear that turns the auger has broken or stripped , the beeeping is to let you know that something has falled. Slow water can be one of several this, the strainer in the water valve is partly stopped up, you could have a kink in the supply line, the water cut off valve could be clogged or the water valve itself maybe going bad.
Jun 23, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
I have a Sharp 32" Standard TV ... picture will get fuzzy either due to someone walking by or sometimes if sound coming from tv is vibrating. If we shut tv off and turn it back on it is clear again. The...
Hello: Your problem seems to be in or around the tuner of the television, More then likely you have cold solder joints on the turner that needs to be resoldered. Also check the coax end protruding from the back of the set where u connect the cable and make sure it is not loose, a bad ground on this connector to the turner shield will cause this symptom. My professional diagnostic is that when the television is cold the solder connections are making contact with the board, and as heat builds up in the television while watching these connections tend to seperate and make limited contact, causing fuzzy picture and in most cases no picture just snow...
Sep 06, 2009 | Sharp 32C-240 32" TV
My speaker sound terrible its like my speaker is grounded
Check your sounds software first, sometimes the software problem can give terrible output, check in the input plug ,the wrong plug can give terrible sound quality if that too doesn
't work see your setting for sounds.
Jun 12, 2009 | Computers & Internet
HDTV Turner
If your set has HD on it means set is HD Ready and you do not need Converter Box even if your only signal is coming from an antenna. Either a TV has HD or it Does not! And NO you cannot buy Parts to make your set HD.
Dec 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
KLH R5100 Receiver Logo
96 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
