Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Delta shower faucet with a single handle lose
My Delta shower faucet with a single handle is loose since I bought the house. I suspect a spacer is missing but I cannot remove the handle.
I have loosed the set screw but the handles does not want to come off.
How can I get the handle off to see what is wrong by myself?
  • 553 Answers
You need a faucet handle puller, you can get these at most home center and hardware/plumbing stores.
Once you get the handle and cover off you might just find that the control was never fully mounted.
Posted on May 26, 2010
How to fix delta shower single knob faucet
Take handle off (either set-screw from side or bottom of handle, or phillips screw under cap on end of handle), pull off sleeve that's behind handle, unscrew nut that holds cartridge (strap wrench works great) and pull cartridge out.
Apr 29, 2015 | Delta & Single Handle Shower Faucet
I instslled new delta single shower faucet ,the water is running for 5 to 10 sec even if the shower handle is in off position
Sounds like someone did not remove the plastic valve assembly before soldering the valve body to the copper piping.
That or the valve body needs cleaned out. It is common for debris to get knocked lose when doing installations on old plumbing.
Jan 29, 2011 | Delta & Single Handle Shower Faucet
Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
Delta shower faucet loses pressure when turned all the way on (hot water). What could cause this? When it first happened yesterday, a few tiny pieces of black plastic/rubber fell out of the bathtub...
Turn off the water to the home. You need tthe stem beneath the handle. Remove the handle after locating the set screw, remove the cylindrical beauty cover, and unthread the retaining nut to access the valve stem. Take it to a plumbing supply house or home store to make certain of the match.
Oct 06, 2010 | Delta & Single Handle Shower Faucet
Delta single handle faucet leaks
BEHIND THE HANDLE THERE SHOULD BE A SET SCREW THAT HOLDS THE HANDLE ON THE STEM. THE SET SCREW WILL BE BEHIND THE LONGEST PART OF THE HANDLE LOOK AROUND BACK OF THE HANDLE. AFTER REMOVING THE HANDLA THERE WILL BE A STEM AND A NUT THAT HOLDS THE ASSEMBLY IN THE HOUSING
Sep 16, 2009 | Delta & Single Handle Shower Faucet
Slow leak old delta
The brass cap unscrews and yes there are replacements. You can find them at any home improvement store.
Sep 14, 2009 | Delta & Single Handle Shower Faucet
Delta single handle faucet. Hot or cold no in between.
well they should be same size but unless you getting more of one then other then sound like mixing valve is not mixing. do have 3/4 hook up to mixing valve? you only need 1/2" to valve.
Jun 25, 2009 | Delta & Single Handle Shower Faucet
Can't remove the housing of a delta 1348 shower faucet for repair
Their is a silver ring around the blue plastic cartridge.You need to unscrew the silver piece counterclockwise.But make sure the water is shutoff first.
Jan 28, 2009 | Delta & Single Handle Shower Faucet
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
413 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
