Fujitsu Fi-4990C On the computer screen we get a message Kofax error: 20092 Peripheral optics malfunction
  • tbstmc May 27, 2010
    thanks
  • 4,737 Answers
This error relates to the scanner's Optics (Flex cable) or with the Scanner Sensor. First of all you need to check the flex cable (carbon wire), if possible replace it. You can also check it's continuity using a multimeter. To check the sensor, you'll need to call the technician to fix it for you. If your sensor is bad, they'll replace it. Or if it's under warranty, better directly go to the retailer and claim your warranty before you do anything. I suggest you to let the technician do it for you unless you are sure that you can fix. If you have the manufacturer's user manual, please refer. I wish you good luck.
Posted on May 26, 2010
Error 2148285
What driver are you using no twain suggests that the driver is not twain compliant. You may need to update the driver with the correct operating system like windows (whatever it is) or is it MAC OS .
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/fi-series.html
Apr 21, 2014 | Fujitsu Fi-4120c2
Fi-5220 c driver for mac
www.kofax.com and search fo fi-5220c. There are some software there for the MAC.
Feb 06, 2014 | Fujitsu fi-5220C Flatbed Scanner
I receive an error F4 on my scanner when I turn it on. Will not scan. Any suggestions?
Hello Larry,
The F-4 error in Fujitsu fi-6240 scanner indicates Background change over unit malfunction alarm. It may be caused by the malfunction of background motor or optical unit or damaged optical cable.
You are recommended to contact the nearest Fujitsu scanner service center for rectification.
Thanks & regards,
ScanCare
Sep 25, 2013 | Fujitsu Fi-6240 Flatbed Scanner
My fi4120c scanner doesn't work with windows 8 - help?!
Hi Lorraine,
Fujitsu fi-4120c scanner has been discontinued and is not compatible with Windows 8. Please follow the link provided below for more information.
www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/fi-4x20c.html
Hope the above information is helpful.
Thanks & regards,
ScanCare
Sep 23, 2013 | Fujitsu fi-4120C Path-Through Scanner
M4099d scanner
Attributed to paper sensor problems.
Clean the little square and round paper sensors under swing arm of
upper feed roller asm.
also clean the clear plastic return reflectors.
these may need changing as they taint after time.
Jan 12, 2009 | Fujitsu M4099D/FI-4990C Scanners
Fi4990C
When the scanner scans the first image it will bring in via a set of solenoids a background white Reference metal flap for both rear and front cameras.
The above error comes about when the solenoids are sticking or they have magnetised themselves.
1.Clean the Solenoids.
if scanner still errors .
2. Replace solenoids.
Dec 30, 2008 | Fujitsu M4099D/FI-4990C Scanners
Non working unit
just clean all mirrors & lense of front side CCD
Oct 23, 2008 | Fujitsu FI-4860C2
Fi-4990c problems- front optical sensor
fi-41990 scanner cleans after scanning 100,000 sheet for paper roller the pad cleans after scanning 100,000 sheets feeding path cleans after 200,000 sheets http://www.fujitsu-europe.com/support/scanner/manuals/consumable-option_3-5-8.pdf
Aug 09, 2007 | Fujitsu fi-4990C Path-Through Scanner
47 people viewed this question
k24674
jasbo
jasbo
