Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
PT-61LCX65 part number LSUQ0100 jig
I am having a difficult time ordering this part. I've contact parts/tech/concierge and they have told me I need a tech with authorization number to order this part. Is that true? Anywhere else I can get it? Suggestions?
Thanks
  • 927 Answers
Good Day, redmango;
Try calling 1-800-458-6053.
Good Luck, big IRISH.
Posted on Aug 26, 2008
SOURCE:
LSUQ0100 how do i use it
go to the Panasonic web sight, armed with the model number of your unit download the user manual, Its free
Apr 26, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Phone number
The EEPROM jig is available ONLY through Panasonic's Technical Service line. A few places offer it for sale, but you still need an authorization directly from the Panasonic's engineers to get one.
The guys will ask for your company name and Panasonic account number. If you are not Panasonic Factory Service center, they cannot even talk to you. (not their fault, it's company policy)
If you are out of warranty, call Panasonic and see if they will give you a one-time concession for repair. Usually the company is pretty good about it...
Good luck, Mark
Oct 18, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-61LCX65 Bulb Reset
hold the volume button down on the t.v. & the split button on the remote at the same time for about 8 to 10 seconds.The t.v. tech. did this with my panasonic 61lcx65. Also I had 2 fairly large red / orange & 1 blue spots on the screen which I thought were a result of the bulb being bad , but the tech. attached a device he called an eeprom jig & it reset the chip ? Now the picture is like new again.
Sep 17, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
LSUQ0100 tool
You have to be a Panasonic Factory Service center. Tritronics
sells them, but you still need an authorization directly from
Panasonic's Tech Support engineers - period. (You will be asked for your company name and account number before they will even talk to you)
If you can get one one otherwise, it's hot and the center that got it for you will lose their authorization should they be found out.
If you contact Panasonic directly, they may give you a concession for repair on this problem. In my experience, once the EEPROM
data is reloaded and updated, the problem is permanently fixed
Good luck, Mark
Sep 09, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Repair on problem blue dot
Good Day, flavrlen;
This is your fix it is not costly and if you handle a screwdriver you can do this in 30 minutes:
PANASONIC:
MODELS: PT-44LCX65, PT52LCX15, PT-52LCX65, PT-52LCX35, PT-61LCX65,
PT-61LCX35.
SYMPTOMS: 1. FUZZY SPOTS
2. FUZZY SPOTS
3. FUZZY SPOTS WITH STAINS
4. FUZZY SPOTS & UPSIDE DOWN
5. FUZZY SPOTS WITH LINES
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM
CORRECTION TOOL; (LSUQ0100).
Jul 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Trouble ordering part LSUQ0100 JIG
You need to be an authorized panasonic service center to get that item.
Apr 10, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Trouble finding part LSUQ0100 JIG
This item is normally only on backorder for 5 days. However, not many store are able to stock this part as it needs an authorization number to order this. You can only obtain an authorization number from Panasonic Tech Support.
Apr 06, 2008 | Televison & Video
LSUQ0100 jig question
The procedure information comes with the part, just follow the included directions exactly and you should be able to do it. have a good day.
Apr 03, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
PT-61LCX65 image reversed
Per panasonic's autorized tech website5.gif it is corrupt EEPROM data. It is corrected using the following jig with included instructions on how to perform software5.gif upgrade.
Correct symptoms using part LSUQ0100 jig that comes with instructions. (operation takes 6 mins)
hope this helps.
Mar 24, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
PT-61LCX65
Per panasonic's autorized tech website it is corrupt EEPROM data. It is corrected using the following jig with included instructions on how to perform software upgrade.
Hope this helps.
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
157 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
