Question about KitchenAid KHHS179LSS Convection / Microwave Oven
The touch pad does not work
You press on it and nothing happens
  • KitchenAid Master
  • 9,085 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Otherwise, you probably have a failed membrane keypad.
Is it possible that some spray cleaner or steam accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
But please note that for some models, the membrane keypad is not
available as a separate part, so you would have to order the control
panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself
job.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 28, 2010
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Microwave won't work - put in food and press START and it beeps and says "PROBE" and nothing comes on. Tried all cancel buttons, even reset the fuse.
    Please check if the pads are working to indicate that the touch pad is outputing data to the processor. If there is no menu selection, clock settings then the pad could have worn off.
    Also check to disconnect the magnetron , the main capacitor and the connections to the main processor board.
    Apr 19, 2011 | Microwave Ovens
    Touchpad is not working
    Hello :
    If touch pad has gotten wet, then allow to dry for several days. Avoid spraying cleaning liquid near touch pad.
    Check for insect infestation. Insects (cockroaches most frequently) will appear under clear surface of touch pad or under readout window; they like the warmth of the circuit boards.
    Place window mesh over vent to keep insects out.
    good luck .
    please rate !
    Mar 29, 2010 | GE Microwave Ovens
    Power went out. Microwave just scrolls press clock!!!!!!!!!
    Did you figure this out? I am having the same problem. I see PRESS CLOCK on the control display. But none of the keys on the touch pad work. GE sucks bigtime !!
    Jan 17, 2010 | GE Spacemaker JVM1540 Microwave Oven
    Start Toaster button doesnt work
    replace the touch pad or, key pad. it has failed.
    Jun 21, 2009 | LG LTM9000 Microwave Oven
    Touch pad does not work, clocke does, nothing else works
    Hi this will happen when the touch pad circuits become unstable and damaged, due to abundant usage or , old age.
    simply replacing the touch pad will fix this issue.
    May 30, 2009 | GE JVM2070 Microwave Oven
    Nothing on my touch pad works
    My microwave way manafacture May 2008. Nothing on the touch pad works.???. It just abrubtly stopped
    after a few seconds.
    We brought it in July or August
    Debbie
    Mar 27, 2009 | Maytag MMV1153A Microwave Oven
    Kenmore elite microwave touch screen stopped working
    Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
    Jun 06, 2008 | Kenmore 63793 Convection / Microwave Oven
    KitchenAid KHHS179LSS Convection / Microwave Oven Logo
    275 people viewed this question
    Top KitchenAid Microwave Ovens Experts
    William Miller
    William Miller
    Chuck
    Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
