Question about Intertherm P3RA-060K Air Conditioner
Fan not working on outside AC unit
How can this problem be remedied? When you turn on AC - the outside unit fan is not working and there is a buzzing noise
  • 674 Answers
The buzzing noise is probably the fan motor. Is the compressor running? First make sure that there are no tripped breakers. After that kill the power and check the capacitor with a multimeter. If that checks good then check the fan motor windings with the multimeter. Let me know if you have any questions.
Posted on May 26, 2010
2 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: Fan will not work on outside unit.
Check the voltage to the contactor coil, it will do that if the voltage is low. This is the 24 volt part.
Posted on May 17, 2009
Turn on AC but outside unit fan doesn't move
Either a very bad Capacitor, or the fan belt came loose and the motor is just spinning
May 26, 2014 | Empire DV-215 Direct Vent Natural Gas...
I have a Goodman CPLE30-1A outside unit and the fan stop spinning. The fan stop spinning so I turn off the main power to the unit and I can spin the fan with the power turn off so I'm not sure if its...
Hello
There are a few things here that could be wrong.
1 Fan motor start capacitor is bad.Silver battery looking device on side of fan.Remove and replace with a new one.
2 Contactor for fan motor is pitted or burnt .If this is the case you will need a new contactor.
3 Fan motor is bad.Check top two before assuming this.
Check all fuses and circut breakers also.
Aug 29, 2011 | Goodman CKL42AR42 Air Conditioner
Inside unit comes on, outside unit buzz's fan does not come on. ac has stoped cooling
TRY TO PUSH OUTSIDE FAN WITH A SMALL STICK IF FAN IS TIRNING ALRADT THE CONTACTOR IS GOING OUT.FAN NOT TURNING STARTUP COMPASITOR IS GOING OUT
Aug 11, 2011 | Gibson Heating & Cooling
Turned on AC was running fine. 30 minutes later began to hear a strange noise. Opened AC/Furnance closet & heard a sound best described as air letting out of a tire. It seemed to be coming from...
Hi!!
This means that the condenser fan motor (outside unit) failed, this caused to build hi pressure and either activated a safety valve to release the extra pressure or blew a line and R22 Refrigerant escaped from system.
The fix is to replace motor fan and capacitor find the leak and refill system with R22 Refrigerant Gas. It is safe to turn on the Fan Only mode on the Thermostat until a HVAC Tech arrives.
To perform this job parts and labor included will cost: about $300 -.$400. Look on the Yellow Pages for a Tech in your neighborhood.
Good Luck!! Don't forget to Rate this post!!
Aug 13, 2010 | Goodman CKL42AR42 Air Conditioner
AC compressor wiil not turn on
You will have to find the contactor which is located in the outside unit. And check the voltage at the contactor, 26 v as this is the thermostat calling for the compressor to come on. You can also push in the contactor and see if the fan and compressor start. There should be an outside fuse box close to your condensing unit. Good luck
Jul 23, 2010 | Samsung AW1203B Air Conditioner
Fan not working on my CPLE36-1C AC unit outside. Why?
Hello Tim First Turn the power off! Try to turn the fan blade with a twig or something.Is it tight ? It should turn freely.If yes open the cover where the wires connect & check if the capisitor is expanded or leaking if so replace that with the SAME one (uf value&volts).Check for burnt wires also.The capicitor is a round or oval shaped can (looks like a large battery) with wires cliped/pluged in on top.Next let the motor cool off 1 hour and restore power.Does it BUZZ for a short time then stop?If yes its new motor time.Good luck
Jul 07, 2010 | Heating & Cooling
Outside AC Unit Making Noise but the Fan is not working
It could be the capacitor on the fan motor has gone bad.
Jul 20, 2009 | Heating & Cooling
May 17, 2009 | Intertherm P3RA-060K Air Conditioner
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
Intertherm P3RA-060K Air Conditioner Logo
617 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
