Question about Hyundai Heating & Cooling
How to replace the hyundai santa fe air
Do you have to take the entire dash out to replace the hyundai santa fe air conditioning evaporator unit.
Hyundai said the dash needs to come out to replace the evaporator but I have been told by 2 others it can be done by removing the glove box and getting to it from there, and mine was done this way.
Posted on Jun 23, 2010
2002 Hyundai Sante Fe 2.7 cd/cassette/am/fm
Internal electronics failure. Whenever this issue rears its ugly head, we replaced the entire unit as no repair facilities are available.
Sep 02, 2011 | 2002 Hyundai Santa Fe
2007 hyundai santa fe fuel 2.7 6 cyl fuel filter location?
how to change the fuel filter on 2007 hyundai santa fe
Sep 20, 2010 | 2007 Hyundai Santa Fe Limited
Picture of the fuse box in a 2002 hyundai santa fe ecu #10 fuse keep blowing when start the car
hi, i need help in fixing my santa fe 2002 ,interior lights wont turn on if i turn the car lights on , the main dash board liths are ok but the remain eq like the gear light (P , R, D N) the air condition lights window switch lights , so at night i cant see the eq.
any idea how to start fixing ? location of the main light source ??
Many thanks
Aug 25, 2010 | 2002 Hyundai Santa Fe
2003 Hyundai Santa Fe Air Conditioning Condenser - How do you replace the condenser? Does anyone have photos, or can you recommend a good manual?
This job requires special tools and training. There is serious personal injury exposure!!!,
The oiling of the system needs to be addressed, the receiver/dryer needs to be replaced, the system needs to be evacuated....etc, etc.
Have a qualified shop do this for you.
May 30, 2010 | 2002 Hyundai Santa Fe
How do I replace fog lights on my 2002 Hyundai Santa Fe?
Look up into the bumper and see if you can access the fog light. The bulb should just twist out of the back. If not, the assembly should either pop forward or back to come out. I've heard though, that many santa fe's require the removal of the entire front bumper fascia just to get to the bulbs in which case you'd have to remove your headlights to get to the screws holding the bumper fascia on
Sep 09, 2009 | 2002 Hyundai Santa Fe
Santa Fe makes jerking motions
the air conditioning changes your idle speed when the compressor cycles on and in some vehicles will cause the problem you have.
it is the design and there is nothing you can do about it
Aug 19, 2009 | 2003 Hyundai Santa Fe
I have a 2002 Santa Fe with auto temp. There is a build up of ice on the evaporator core. What could be causing this?
One possible cause would be insufficient airflow through the evaporator to heat the refrigerant. Do you have in-cabin air filters in your car's HVAC system? The owner's manual may teach you how to change them.
Jun 17, 2009 | 2002 Hyundai Santa Fe
Hyundai santa fe ac
I didn't get your response to my response. I guess you're not listening/watching. Here's the solution. Take vehicle to Hyundai Service Center - When in doubt, find out from the professionals. This way you'll know what you need to know and Nuff said. Agreed?
May 11, 2009 | 2001 Hyundai Santa Fe
What is a 112 and a 444 code on my hyundai santa fe
Code PO 112 is intake air temperature circuit low input and PO 444 is Evaporative Emission control system purge contol valve circuit open. Both codes could be sensor problems or wiring problems.
Mar 11, 2009 | 2001 Hyundai Santa Fe
Santa fe blower motor
1.disconect the neg. fron battery.
2.the blower unit is located under the dash and behind the glove box.
3.open the glove box disconnect the cord.push inwardson the sides to lower the door fully.
4.remove the dash panel to the right (has one screw)
5.remove the inner frame scrrews (four screws)
6.remove the blower/evaporator mounting bolts and remove blower motor.
7.tranfer the fan to new motor prior to installation.
8.installationis the reverse of removal.
f.y.i. use pliers to release and remove the clip holdin blower fan to th emotor
Dec 13, 2008 | 2003 Hyundai Santa Fe
Heating & Cooling Logo
398 people viewed this question
Top Hyundai Heating & Cooling Experts
gbob59
Arnie Burke
Arnie Burke
cwradio73
Are you a Hyundai Heating and Cooling Expert? Answer questions, earn points and help others
