Qsc 2450 amplifier not putting out equal sound to both channels. checked speakers and cables they are ok. i have narrowed it down to ch2 on my amp. can someone give me some pointers on what to look for inside of amp? looks brand new inside.
  • 17,130 Answers
First of all , the fault of a unequal volume levels is a fault to be looked in with some expertise. This is because of the fact that there is no failure but a difference in gain in some stages. If you have crossed over the speakers and confirmed that the fault is definitly in the amplifier. Now you will need to check first with a multimeter for diffferent bias in the preamp and power amp stages. If you have evidencce of a difference cross check to confirm. Next apply an audio signal from an injector and test from the preamp to the power amp. The section where the gain was noticed must be looked into and the gain corrected by checking variation of resistor/ capacitor values. You will need to replace fromt he working side- crossing the good part- to confirm the part before you buy and replace. Try this out but do it with caution when the circuit is powered , attempt only if confident and familiar with circuits. Hope I could help. Good day
Posted on Jul 24, 2010
What is briged mode
I think you mean bridged.Which it is when you have for example a 2 Channel amp but instead of hooking Ch1's + & - or Ch2's + & - to the terminals on your speaker you would instead hook a + from Ch1 then the - from Ch2 to your speaker. The purpose is to increase the rms wattage being delivered to the speaker. Be sure to check what ohm stable your amp is while bridged though cause if the load is to low the amp will not last long.
Jan 21, 2013 | Kenwood KAC-7204 Car Audio Amplifier
How do I bridge my QSC GX 3 amp to run one speaker cabinet?
For QSC amps the GX series are not bridgeable. You will have to run one speaker to each channel.
Mar 22, 2011 | QSC GX3 Amplifier
Quiet Amp
sounds like you need a preamp. i would need more info to be sure. good luck
Feb 11, 2010 | QSC CX302 2-Channel Amplifier
Channel 1 works fine but channel 2 doesnt put out anything. how can i fix it?
if you have indication of signal input for both channel you can go and reverse output cables of the speakers if the problem transfer to good channel change speaker cable-if you did not have input indication in the bad channel try to inverse input cable if it is cleared change your input cable if not you will have internal trouble and need service center to help.
Dec 14, 2009 | QSC MX1500A 2-Channel Amplifier
Soon as i turn on my QSC RMX2450 the clip light comes on for Ch 2
Sounds like an output going bad. Try to get some electronic contact cleaner and spraying on the circuit board. If its corroded this will help clean the circuit..
Sep 07, 2009 | QSC RMX-2450 Car Audio Amplifier
QSC ISA 280 Stereo Power Amp stopped working
This is a very precise questions as QSC amp are pretty rare and high end electronics equipment. There is no way getting an answer other than getting the amp at a sound shop for repair, wich might go for a visit at QSC anyway. From a sound shop repairman...
Sep 07, 2009 | QSC ISA 300Ti Amplifier
QSC 2450 Power amplifier
i have a pyle pro 1000 watt max 2 channel mono and 2 channel stereo and when i get that thing loud the little red light cums on basically what i mean is that the amp on channel one is cooked i myself i wouldn't even use it y cause more damage
Apr 03, 2008 | QSC RMX-2450 Car Audio Amplifier
Another question for zzedly about the speakers cutting out
So, as I see it, your system is hooked up like so:
  • Ch1 = Left speakers, front and back
  • Ch2 = Right speakers, front and back
  • Ch3 = One sub
  • Ch4 = Other sub
One thing you can try is swapping channels. Swap Ch1 with Ch3 and Ch2 with Ch4. Then see if the issue still occurs on the door speakers or do the subs suddenly cut out at loud volume. If the subs start cutting out, that means the issue is with Ch1 and Ch2. If you haven't already, check the RCA connections to Ch1 and Ch2 as well as the gain for all channels. If the gain isn't already set to about 50%, put it there.
Mar 14, 2008 | Kicker IX404 Car Audio Amplifier
70 people viewed this question
 Grubhead
Grubhead
