Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
I removed the rear access area on my ES3250 all in one printer and can't reinsert it. Is there a picture that would help?
    Problem Solver:
  • 19 Answers
Http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/ESP3250/ESP3200Series_SUG_1K5812_en.pdf
Download this file. It is manual for ESP 3250 printer
Posted on May 28, 2010
The printer says the the door is open but it seems closed
Check the rear access panel.
If there are copper contacts on the rear panel that you can see when it's removed, pull them out a bit so they are "springier" and reinsert the rear panel. This is the most common issue for that error with HP inkjets.
Jun 20, 2011 | HP Deskjet 6980 InkJet Photo Printer
It shows "remove any obstruction
Open the printer cover and access the cartridge area. Remove both cartridges. While the cover is open, check for any obstructions in the cartridge carrier's path. Check for any loose transparent strip (encoder strip). If cartridge area clear from these, Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, open the printer cover and reinsert the cartridges. Close the cover and try to print again.
May 27, 2011 | Lexmark X4650 InkJet Printer
Error code 0x61011beb / HP Photosmart D7560 / Printer will not Print DVD Media
Solution 1: reset the printer:
1. Switch on the unit.
2. Open printer and remove all cartridge.
3. Unplug the power cord from the printer.
4. Unplug the cable from the wall outlet
5. Wait 30 seconds.
6. Plug the power cord back into the printer.
7. Plug the power cable directly to the wall outlet.
8. Open the top cover and reinsert the cartridges.
9. Turn the unit on.
10. Print a document to test
Solution 2: If the previous solutions did not work, check and clean the printhead:
  • Step one: Remove the printhead:
1. Press the Power button to turn on the product.
2. Open the cartridge access door.
3. Remove each cartridge.
4. Lift the latch handle on the carriage until it stops.
5. Lift the printhead straight up to remove it.
  • Step two: Clean the printhead
1 - Plastic ramp on the side of the ink nozzles
2 - The edge between the ink nozzles and the electrical contacts
3 - The electrical contacts
CAUTION: Do not touch the ink nozzles. Use only cleaning materials to touch the electrical contact areas.
  • Step three: Reinstall the printhead
1. Raise the latch handle, and then reinsert the printhead.
2. Carefully lower the latch handle before reinserting the cartridges. The latch must remain down to install the cartridges correctly.
3. Slide the cartridges into their appropriate slots until they snap firmly into place in the slot.
4. Close the cartridge access door.
Hope this helps
Please rate this solution, thanks!
Mar 09, 2011 | HP Photosmart D7560 InkJet Printer
I am getting ink error message Oxc19a0013
Is the phrase "Ink System Failure" in the message?
First check the cartridges. Remove all of the cartridges. Replace any that are low or empty. Check for damage or a blocked vent. Clear the blockage with a pin. If it is clogged with tape or the orange tab (that was in place during shipping), then remove the tape. Replace any that are damaged. Reinsert the cartridges and make sure that they are fully seated (clicked into place). Check if the error persists when you close the cartridge access door.
Try running the printhead cleaning utility from your computer. (HP Solutions Center under Setting, Print Settings, Printer Toolbox and follow the on-screen directions).
Remove the printhead and clean it. Then reinsert it and make sure it is fully seated. Remove the cartridges, lift the latch handle on the right and lift the print head straight up. This is done with cotton swabs or lint free clothes (coffee filters will work) and distilled or bottled water. During the cleaning do not touch the nozzles; also do not touch the contacts with your fingers. Wet the swab or cloth and wring out the excess water. Wipe the contacts on the printhead with the damp cloth first by wiping up towards the nozzles. Then with another damp cloth wipe the edge between the contacts and the nozzles (work in a right to left motion). Finally wipe down the ramps going away from the nozzles with another cloth. (Wipe each part until there is no ink left.) Dry each area with a fresh cloth.
Next take another damp cloth and wipe the contacts inside the printer. (work from top to bottom.) Dry the area.
Reinstall the printhead and lower the latch handle. Then reinsert the ink cartridges until they snap in. Close the cartridge access cover and check for the error message.
If the error persists, reset the printer. With the printer on, disconnect the power cord from the back of the printer. Disconnect the other end of the cord from the wall outlet. Wait at least 15 seconds and then plug in the cord (first to the wall outlet and then the printer). Turn on the unit.
If the error persists, then either the printhead needs to be replaced or the unit needs service. Unfortunately a new printhead is not returnable if you put it in and find the error persists.
For details and pictures: see http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3737195#N65 .
I hope this helps.
Dec 12, 2010 | HP Photosmart Premium C309A All-In-One...
6110xi leaves a dark line on the right 1/3 side of the printed page. It usually looks like just a pressure impression mid print and sometimes leaves other 1/2 spaced ink smears on the borders. The...
Print is skewed
  1. The rear access door might not be fully locked into place, causing the paper to skew in the all-in-one. Remove the rear access door by pushing in on both release tabs as shown in the figure below. Inspect it for damage, and then reinsert it. Make sure it is securely latched in place. Figure 6: Releasing the rear access door latch on one sidec00222462.jpg Figure 7: The rear access door removedc00222463.jpg
  2. The paper feed rollers may be dirty. Over time, paper fibers and dust will stick to the rollers and should be removed.
    1. Unplug the power cord from the back of the all-in-one and open the front to expose the print mechanism.
    2. Gently wipe the paper feed rollers with a soft clean cloth slightly dampened with clean water. These rollers may be rotated with the power unplugged.
    3. Remove the rear access door shown in the figure above and wipe the paper supply feed rollers. These rollers may be rotated with the power unplugged. Allow the water to dry for five minutes before reinserting the rear access door and locking it in place.
    4. Close the all-in-one and reinsert the power cord.
Apr 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Green power light is flashing for no apparent reason
Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Jan 02, 2010 | HP DeskJet 3940 InkJet Photo Printer
I have a paper jamb. Page 45 of the manual says to open the rear access area and pull out the paper. There are no drawings showing how to access this area. How do I open the rear access area?
Gently press and hold the tab on the left side of the rear access door assembly. Carefully pivot the left side of the rear access door assembly toward you to remove it.
Note: Before you remove the rear access door make sure to remember the original position of the rear access door., base on my experience its really hard to reinsert the rear access door. GudlucK
Nov 03, 2009 | Kodak ESP 5 Printer
Paper not feeding not catching on the wheels
-Remove the paper from the paper trays.
-Fan the stack of paper.
-Turn off your printer.
-Remove the power cable of the printer
-Lift the main tray, then remove foreign objects or debris.
-Remove the rear access(back door) cover from your printer, then check for foreign debris the remove it
-Clean the rollers of the printer using a lint-free cloth with small amount of water
-let the rollers dry
-Reinsert the rear access door (back door) cover
-Fan the paper and put it on your paper tray
-Plug the power cable., wait for the printer to initialize
-Do a test Print., If its still not feeding please download your latest Firmware at kodak.com/go/downloads
Now if all the troubleshooting did not solve the issue please call kodak for service and repair Toll Free 1 800 421 6699. GudlucK
Nov 03, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
HP DESKJET 3820 GREEN LIGHT FLASHING, WILL NOT PRINT.
Issue
Solution
Close the cover.
Issue
Printer is out of paper
Solution
Issue
Printer has difficulty picking up label media
Solution
Issue
Solution
  2. Press the Power button once. Wait a moment for the paper jam to clear.
Issue
Solution
Issue
Solution
Cyber kaka
Dec 08, 2008 | Office Equipment & Supplies
Paper feed error
Cleaning paper rollers
  1. Turn off the unit, then unplug the power cord.
  2. Remove the rear access door. See the picture above.
  3. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. Figure 7: Paper rollers c00109674.jpg
  4. Allow the rollers to dry completely, then replace the rear access door. Put the pins on the right end of the door into the holes on the right side of the rear access area, then snap the door shut.
  5. Plug the unit back in and turn it on.
Jan 12, 2008 | HP PSC 1210 All-In-One InkJet Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
168 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
