Question about Maytag 24 in. MDB7601AWS Stainless Steel Built-in Dishwasher
Won't drain completely. leaves just enough water that you can feel it with your fingertips. no clogs in the lines. could it be the drain pump or something else. same problem occurs on all cycles.
  • Maytag Master
  • 19,396 Answers
Hi.
The most common cause for the problem is a defective pressure switch. The pressure switch is used by electronic control to detect water level and stop the drain pump. If the switch is defective, the pump may stop too early.
See full troubleshooting here: My washing machine does not drain.
Regards.
Posted on May 26, 2010
Speed Queen, cleared clog in pump, still won't drain
The clog may have moved from the pump to the drain line. If the pump overflows, it would make sense to check the drain line to determine whether it is restricted. The drain line is usually clamped onto the pump outlet and can be disconnected by removing the clamp. You can insert a piece of wire or a drain auger and confirm the state of the line. Doing this may prevent an unneeded pump replacement
Mar 07, 2013 | Washing Machines
DISHWASHER IS NOT DRAINING COMPLETELY, LEAVING ABOUT 2 IN OF WATER
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | KitchenAid KUDS301V 24 in. Built-in...
Dishwasher won't drain when cycle is complete. Not even when press on the Cancel/Drain button. Engine starts working (at least sounds like something is going on) but not water goes out to the sink...
Hi
Daniel
Aug 30, 2011 | Dishwashers
My HE2 front loader has a problem draining. It will be "locked" after washing. It is either full of water still, or needs to go through an extra "rinse and spin" cycle to drain the...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely, if the issue returns then it is time for a new pump. Hope this helps... Please post back for any further assistance.
Daniel
Aug 28, 2011 | Kenmore HE2 Plus Front Load Washer
Dishwasher started to wash then it stopped. Now there is water standing in the dishwasher and won't drain.
Hi
Daniel
Aug 22, 2011 | Kenmore 24 in. 16022 Built-in Dishwasher
The dishwasher does not drain-- it leaves about 1-2" of water in the bottom after running a cycle
Hi
Daniel
Aug 16, 2011 | Dishwashers
Won't drain after rinse cycle.
Hi
Daniel
Aug 14, 2011 | Maytag Dishwasher
The dishwasher won't drain completely. Water is left standing in the bottom of the tub.
Hi
Daniel
Aug 02, 2011 | Dishwashers
GE dishwasher GSD2230 won't drain completely after it completes entire cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
May 18, 2011 | GE 24 in. GSD2230Z Built-in Dishwasher
My washer will not drain completely. It drains, but still leaves clothes with more water than usual
Check for a kinked or clogged drain line. The hose can be removed from the pump and the pump can be checked for clogs. Take a flashlight and look into the suction port of the pump and look for any obstructions (like the occasional stray sock, for example). Also check the pump impeller for broken or missing blades and ensure that the impeller spins freely. If not, the pump is defective. Hope this helped and best wishes.
Aug 14, 2009 | Washing Machines
Open Questions:
Maytag 24 in. MDB7601AWS Stainless Steel Built-in Dishwasher Logo
170 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
