Question about Danby DAC6003D Air Conditioner
Open or closed
I am trying to figure out if the flap should be in the open or closed position when using the fan/AC.. please instruct... Thanks!
  • 901 Answers
Keep the flaps open to the required direction. Generally you can not close 100%
Posted on May 27, 2010
The seal or flap between the french doors doesn't retract
check it closely something has broke an the flap is not closing as u close the door
Jun 28, 2014 | Samsung RS2556 Side by Side Refrigerator
I'm getting an intermittent loud flapping sound when the AC is turned on my 2009 Smart ForTwo
Question. Is the flapping at a very fast pace that would indicate the speed of a fan blade hitting something? If so, you may be on to something there such as a misplaced gasket or something has dropped/fallen into the blower box via a vent.
If it is not that speed then see the following..
Hope I can give you some direction. Speaking from a generic sense all ac/heaters these days have a door or doors in the blower box that control air flow from the main part of the box to different positions when you ask for vent, heater, mix, defrost etc..
Most these days are operated with a small electric servo/motor and unfortunately the mostly have plastic gears that wear and can "thump-thump" as the motor cycles trying to open or close the flapper door.
Try to change the air direction from Max AC to regular ac to heater, defroster, bi-level etc all with the AC switch in the on position if you have a separate on/off switch.
Listen to the sound and see if it comes and goes with a different location of the selector switch.
One last question. Does it happen at idle or driving down the road at any particular speed?
Lets start with that and see what happens. This is interesting.
May 28, 2014 | 2008 Smart fortwo
How to install spring on french door flapper/divider for Samsung RF266
On mine one end of the spring broke off in the hole on the door. It was on top of the hinge so it looked like a pivot pin. I found that this was the second hole for the spring. I pushed the end of the new spring up under the hinge and popped the broke piece of old spring out. Now I could see the 2 holes. You then need to put the spring into each hole. The hole on the flap also needs a white plastic sleeve if that is missing. that goes on the end of the spring and fits into the flap hole. Then the trick part is understanding how the spring works? If you put both ends of the spring in the holes and shut the flap, it now stays in position to close and be flipped open by the guide that swings it open to seal.
Good Luck.
Feb 03, 2014 | Samsung RF266ABRS Bottom Freezer...
Why does my heater work "sometimes" but mostly blows cold air?
There is a flap on your fire wall or inside at the bottom of your dash that opens when your AC is on and stays closed when the heat is on the flap might be sticking its simple to find and fix try to locate it you can open and close manualy
Feb 01, 2013 | Cars & Trucks
Hi there, I have a LG ac through wall/window unit LWHD1200FR 11,500 BTU. It's have a Open vent/Close vent mechanism by the front louver from where the cool air comes out. I would like to know what...
The OPEN is to be used when the air temperature is cool enough, not to have to use the AC. When it's open, the fan continues to operate and pulls cool air in from the outside and circulates it inside the room. Generally, this is only used at night, when temperatures are milder and there's less humidity. When it's CLOSED, the AC is in cooling mode and only the inside air is used to cool and is exhausted as needed. Hot, humid days & nights are when it should remain closed.
I hope this helped you & thanks for choosing FixYa.
Jul 29, 2011 | LG Electronic Window Air Conditioner
It sounds like the blend door in the air ducts on my 1997 Chevrolet Silverado Ext. Cab just keeps flapping and flapping and won't stop. Every now and then it will quit doing it for a while but then it...
what i do in cases like this is to wedge it in the open position with a piece of wood or put a spring on the operating lever to hold it open so you are only using the recirculate mode which is good enough if you use the AC a lot
May 19, 2011 | 1999 Chevrolet Silverado 1500
BUMPING NOISE UNDER DASH
Most of the time this noise is heard when a temperature actuator has gone bad, you can check this by changing temperatures and noting if the noise changes in sound. If so then replaced the actuator. If no change is noted, then open and lower the glove box and while changing from a/c to max a/c, check that the recirculation door is moving into place and not flapping. if flapping, the recirculation door is broken and will need replacement.
Oct 07, 2009 | 2003 Ford F250 Super Duty Crew Cab
The freezer section of my fridge freezer side by side has broken down and will not freeze. The fridge side seems fine. Is it worth getting repaired? Prior to this I often heard like a clicking/ tapping...
So your refrigerator section is cooling fine ? When the compressor motor is running and you open your freezer, is the fan running ? You might need a simple fan replacement - The most costly repairs to a refrigerator is usually the compressor - as long as your compressor is running and you have cooling, the other most common problems are control board faults, evap fans, defrost timers, all of which can be fixed.
Is your freezer iced up when this happened - turning the refrigerator off and unplugging it, try removing the back panel of your freezer and locate the fan - look for anything obstructing the blades - maybe ice or other......otherwise you may need this serviced.
Is it worth it ? It depends - how much did you nitially pay for this ? How long have you had it ? How much are estimated costs for the repair - if the problem is one thing needing replaced and doesn't cost you a lot of money, yes it is worth it.
Aug 17, 2009 | Whirlpool GS6NBEXR Side by Side...
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
1997 mercury marquis ac & blower
you could have. Take a look and find out. If the lid/cover of the fusebox does not name the fuses and relay's check owners manual, find the fuse(s) and/or relay and check it out.
Relay can be tested in a few ways,
first, easiest way get a buddy to go in the vehicle and switch your AC on and off, find the relay and get in real close and listen and feel for the relay clicking as he turns it on and off, if the relay is clicking it is most likely working fine.
if you are unsure on relay working you can try this method: theres usually 2 switches one is normally closed one normally open. Using a multimeter and the electrical diagram that should be on the side of the relay itself you should be able to figure out which switch is normally open and which is normally closed. Look carefully sometimes the writing, labels and numbers are hard to see.
Another possible cause is that your temp sensor failed so the computer thinks its -40 degrees and therefor won't run the fan. check the temperature sensor wiring, and the sensor itself after you look at fuses and relay operation.
Hope this helps :)
Sep 04, 2008 | 1999 Mercury Grand Marquis
Danby DAC6003D Air Conditioner Logo
108 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
