Back to:
Tags:
Tascam 302MKII Single Cassette Deck
Right side deck problem Tascam 302MKII
posted by N8AJB on Apr 07, 2008
Hi There -- This is a "new old stock" unit that has never been used. The right side deck will fast forward or rewind but the heads do not come into position for play or record. Any ideas?
Thank you ... Alex
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 19, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
That part number was 095-3M002870. Some how I did not get the M in there..
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on right side deck problem Tascam 302MKII:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Guest
Rating: 0%, 0 votes
I have the same unit with the same problem right out o the box. The problem is the Capstan motor. Replace it and the unit will be perfect. The part number is 095=3002870. The best place to get it is at Full Compass. 1-800-476-9886. They are much easier to deal with than Tascam. They will even send a blow up of the section to help you replace the motor. The motor is around $38.00 but well worth it. With out it you anly have half a deck.
Thank You!
Solution #3
posted on Apr 07, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
just buy a new one
Thank You!
Can you Help with these Tape Decks problems?
Tape Decks
my cassette is stuck inside my stereo dont want to force...
Tape Decks
my sharp GF9292 is 15yrs old .The problem is i play tape...
Tape Decks
Tascam PS-M30 ac adapter needed to power a Tascam MTS-30...
Tape Decks
Could you kindly inform me or you can send one flat belt...
Tape Decks
I have wow and no rewind
Loading problems.
Repair Service
Find Tape Deck Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
