Question about NEC Televison & Video
NEC NLT32HDEM1 Black Screen on DTV Stations
I changed the channel on my Digital TV and the screen went black with no sound. now i cant change the station to any other channel but when i switch over to analogue TV it is fine.
skotkolr
  • 558 Answers
SOURCE: no picture
bad capacitors in the power board area these can be replaced and soldering is required to replace them
Posted on Dec 09, 2008
SOURCE: westinghouse lcd 26" has blue screen and no sound
1. plug it into a input device (well duuh)
2. it could be a fried mother board or a cracked one !!
3. it could be the sound plate a gt674jj49329710hfwllw plate u need u probably have a gt683jj63835540gdhdys plate !!
4. take it back !!
Posted on Jan 03, 2009
  • 19 Answers
SOURCE: LG 42LG30 TV will not scan in DTV stations
Sounds like you're having a problem with your main board assembly. The main board is what processes all your audio/video signals. So if it's not scanning DTV you've probably got a bad card. Call LG's customer support line at 1-800-243-0000 and have them schedule you a service call. Request a DMST if there's one available in your area as they actually work for the factory. Otherwise you may get an ASC(authorized service center) which can be less than reliable at times when it comes to customer support and satisfaction.
Remember to have your proof of purchase handy as well as the full model and serial number. And by model number, I don't just mean 42LG30. On the side or back of the unit there will be a manufacturer's code. The first part is indeed the model#. However, it will appear something along these lines:
42LG30-UA.AUSRMJR or something similar to that.
Have that ready definately. Any tech worth their salt will call you a few days beforehand to try to get that data so they can order boards before coming out there, saving them, and you, an extra trip when they have to come and order boards. Without that extended manufacturer's code, LG techs have a hard time with a lot of models trying to order parts as different revision codes and such use slightly different circuit boards.
Posted on Feb 21, 2009
  • 124 Answers
SOURCE: Samsung plasma all black screen
Black Screen come from three areas. 1- Power Supply Board 2- Inverter Board 3- Processing Board on the LCD. Since the Power Supply Board was replace, it easy to troubleshoot where the problem. lies If you cannot get the backlight, then its the inverter board. If you can use a flash light on the TV screen and can barely see the images, then the problem is indeed the inverter board. If you cannot see any images when using a flash light, then the problem comes from the LCD processing board. Let me know if you have any success. Mike
  • 34 Answers
SOURCE: My LCD won't tune into DTV
You need to go to your menu option with your remote. Select channel scan from the options listed in setup. This will allow the turner to find your DTV channels again. Hope this helps. J
Posted on Apr 09, 2009
Maxent tv repair
time to replace the Tv unfortunately
Jan 29, 2018 | Televison & Video
Sanyo TV - black screen, sound find
The black screen on your Sanyo TV is symptomatic of power supply failure
Jun 03, 2013 | Televison & Video
The DTV input in my GV46L stays black. Why?
You don't say what you are trying to input but take note that your model does not have a digital tuner on the DTV input. If you use a digital OTA antenna, the signal must first go through a digital converter or tuner before it goes into the DTV input. The DTV/ANT input is only cable ready. There is no digital tuner in the TV to activate the DTV menu.
Nov 02, 2012 | Vizio GV46L 46 in. LCD Television
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Vizio GV47L screen went black and is now unresponsive
Could be the power supply gone bad.
No easy solution I'm afraid.
May 20, 2009 | LG 47LC7DF 47 in. LCD HDTV
Direct Tv Receiver No sound Black Screen
unplug the power from the reciever for a few moments. plug it back in and let it load. once its finished turn to channel 201. Usually it the reciever is on an unavailable channel (channel with no programming) when it restarted it will go back to that unavailable channel hince the black screen and no sound.
Jan 01, 2009 | Philips DIRECTV H20 DTV Receiver
Black box comes up on tv screen
The black box is a text box for closed captioning. Some stations send the signal which turns on the box while not actually broadcasting any text. Go into your setup menu and turn off closed captioning, or at least change it to a different mode. The easiest option is to restore factory presets.
Nov 28, 2008 | Polaroid FLM-3732 Television
Black screen
you mean no picture just sound?
lost high voltage...... check Horizontal output transitor and flyback.
Sep 14, 2008 | Orion1934 19" TV
No picture but sound
How did the cable person hook up the cable? Was it thru an rf connector and you need to put the tv on A channel . Or are there video and audio cables from the cable box to the tv? We need to have more info please. Thanks
Jun 12, 2006 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
85 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
