Question about Onkyo PTS-707 Shelf System
My Onkyo cd player will not open to change a cd. I have to tap its front and it may open or harder if it refuses. Need help
    President:
  • 1,099 Answers
the problem of the system could be either the rubber attached to the motor is too big, cut ,
OR
the mechanism of the system needs adjustment.
Replace part with the same size.
Hope this will help...
You have to do this by opening the cover of the system.
Posted on May 26, 2010
Dx7355 locked
Set your Player back to Factorysettings. Push "Skip forward" and "Repeat" at the same time. "Clear" appears on your display.......now you should be able to open your deck.
Jan 13, 2013 | Onkyo Dx-7355B Cd Player - Black
ONKYO CR-315 cd player locked.
Hello
Just try to reset the CD receiver by holding the clock call button and pressing the STANDBY/ON button.
Nov 30, 2011 | Onkyo CS5VL Super Audio CD Player Black...
The door to the turntable will not open and the turntable just keeps trying to change. Had to unplug it to make it stop.
There is a problem with the rubber belt that drives the door of the turn table. Open the cd player and replace the rubber belt.
Nov 17, 2010 | Onkyo Audio Players & Recorders
Onkyo DX-703 CD tray engine tries to oepn but cannot when I put CD player on and hit open. What can I do?
You're tray may be opened with a belt, maybe it's slipping over the plastic wheel.
Good luck,
Gerard
Jan 14, 2010 | Onkyo DX-C390 6-Disc CD Changer
The repair shop suggests sending my cd player to the manufacturer. How do I find out where and if possible? Can't get loading tray to open - seems jammed. Model C-707CHX
Hey there
Usually there is a lttle hole in the front panel near the eject button. All you need to is insert a pin into the hole and just pull open the trey.
The button in the little hole releases the locking mechanism so the trey can move out freely.
Please rate solution
Best regards
Sep 15, 2009 | Onkyo Audio Players & Recorders
I cannot open the CD driver to run EZTune. The images on the monitor are in Japanese, and I would like to change the language. I would also like to run other installation CDs. I've tried the remote, a red...
without knowning what type of cd player you are talking about... get a paper clip and open it up so you have part of it somewhat straight with the cd player power downed and unpluigged... there is usually a small whole on the front. Push the paperclip in you can force the front out it requires some force but wait until the clip doesn't go further then push harder.
Dec 05, 2008 | Computers & Internet
Open & close button Does not work
Being that it is an old unit, even though it worked just fine except I had to open and close the drawer by hand. I sent it to the trash bend, It was an Onkyo C110. Thanks anyway!....Bob
Nov 19, 2008 | Onkyo DX-C340 CD Player
CD Carousel for the Onkyo Shelf System
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Oct 11, 2007 | Audio Players & Recorders
119 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
