Question about Philips Magnavox 51MP392H Rear Projection Television
Blue Color Convergence wont adjust
I saw your answer to the guy who asked about fixing his tv himself, and was wondering if I could do the same. My Magnavox 51MP392H/17 will not allow me to adjust the blue convergence up or down, only left and right. It appears to be about one inch low on the manual convergence screen. Is this something I can tackle myself?
Thanks,
Mike C
Dunedin, FL
  • Zero-G
    Zero-G Nov 20, 2008
    I have the same problem and replaced both IC's with better 150's and replaced all the 12 metal film resistors with 6.8 ohm parts. I did this 3 times now and still cant get the BLUE to move up and down, are there any other parts that control BLUE up/down other then the IC STK392-120's and the 12 (6.8 ohm) resistors? what do those transistors control?
    I posted my detailed problem else where but wrong spot on this site I'm going to repost it in this message thanks for reading...
    OK, I got a good one for you techies...
    so I replaced the ICconvergence chips and my 12 resistors, theapparently my 6.8 ohmresistors were not the right type "not metalfilm?" or my solder job wasnot up to par, either way 2 burned up. Ireplace then and the ICs withall new chip this time the quality ones.the TV run stable the redadjusts fine
    HOWEVER,
    1. The Blue convergence with not move up and down just left & right. I've tripled checked the sodder even redone them and checked the ohms they are good... red works perfect, green is bent on top
    What else controls the the "Blue convergence up and down?"
    I read the parts manual online but can't decide if those 3 prong Transistors effect the convergence control and if so which one?
    2. the Green "non movable fixed color" has a warp/bend top center TV screen the top two center mulit point convergence points warp left. see below crued sketch, also most of the center multi points red/blue are right on BUT the outer ring red/blue + are pulled IN away from green
    IGNORE THE DOTS, I needed them to hold the space to keep the lines from moving to the edg of screen in drawing for the GREEN screen bend which remains constant after all 3 IC replacements attempts
    ______________________________________________________
  • Philips Master
  • 8,617 Answers
Yes by all means . I will post a link where you can get your replacement ICs along with free installation instructions with pictures. They also provide free on-line instant messaging while your doing the repair which only takes about an hour from start to finish. I am one of the support techs. Your model uses STK392-110 or STK392-120 either IC interchanges with each other except the 120 is a better IC runs cooler.Heres the link.You will need to replace both ICs
http://servicemanuals.vstore.ca/
Posted on Apr 07, 2008
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
I have a PT-53WX53 CRT rear projection widescreen tv. The guns off and the red and blue are no longer aligned. I tried to adjust with the 9 point convergence correction but it only helped a bit. I know...
Convergence + - don't alignment or some mis alignment anywhere in the picture.The R,G,B colors lines don't move any of the color line.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergencce board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 27, 2010 | Televison & Video
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Tv shows double vision in blue color. how to fix this problem?
This is a problem with your convergence settings found under your tv's menu. its very easily fixed, you just need to open the setting for convergence and use the arrows on your remote to adjust. inproper convergence can cause either a red or blue haze around almost any object displayed on the tv screen
Apr 14, 2010 | Samsung HC-P4363W 43 in. TV/DVD Combo
I have some distored blue color across the screen
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Mar 27, 2010 | Panasonic PT-53TW53 53" Rear Projection...
The green color seprate from red and blue
If either blue or Red will not adjust in some direction this 2003 model has a bad convergence IC; it uses two STK-392-560 convergence IC chips that you can buy on Ebay(Suburban Electronics is the best source) for less then 13 dollars plus shipping--most of the time just need to replace both and then adjust the set--I have fixed hundreds of these sets---if this has been helpful give me a vote here--if you need direct assistance-=-
etower.766@netzero.net
usually this can be fixed right in your home--I know---I do a lot of them here in the San Diego area where I live.
Aug 17, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Wont autofocus, bow in blue color at top, cant adjust blue convergence
hello it's the convergance chips my be the problem get a quote from an engineer its a big job 2 do yourself trust me i've repaired a few my self i hope you get it fixed good luck
shaun
May 21, 2009 | Samsung Televison & Video
Sony -kp65wv600
I got this TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Jan 11, 2008 | Sony KP-57WS500 57" Rear Projection...
Blue and yellow color
Blue should converge on top of "yellow".Bad connection(s)
on blue convergence IC.Replace both IC's for durable repair.
Check pico fuses.Reset convergence alignment.
Oct 17, 2007 | Samsung HCL552W 55" Rear Projection...
Mitsubishi VS60603 convergence
Sep 20, 2007 | Televison & Video
Philips Magnavox 51MP392H Rear Projection Television Logo
123 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
