Question about Remington Electric Chain Saw
3.0 Peak HP 16'/41 cm remington
Chain does not move or stalls when i try to cut a treei have tighten the chain
  • 553 Answers
You might actually have the chain too tight. With the saw off you should be able to lift the chain until the gear tooth (tooth on inside of chain) almost lifts out of the chain bar.
I've never used an electric chain saw but if it has a chain oiler you should also check your chain oiler to make sure you're getting enough oil on the chain, if you run the saw with the chain aim at a clean surface you should see oil on the surface almost immediately.
Posted on May 26, 2010
I have a Remington 16"
most any bar and chain oil for chain saws will work. The cheaper the better just make sure you keep the chain oiled up. if you can touch the chain and oil oil does'nt get on you you not using enoght and put oil right on the chain. certainly when you put the saw away to store it. even wrapping the bar and chain in a rag with oil in it is a good idea as it'll be ready for next time.
Jan 31, 2011 | Remington 16" Electric Chain Saw Assembled...
What kind of oil does a Remington 3.25 (Peak hp) 16"/40, 6 cm Electric chain saw take
You need to use bar & chain oil. It's thicker and stickier that regular oil so it will stay on the bar and chain and not run out of the saw when you are done using it.
Jan 21, 2011 | Remington 16" Electric Chain Saw Assembled...
I have an Remington 3.25 (Peak Hp) 16"/40, 6 cm electric chain saw, And I have just a few questions 1.) Does it take oil/gas or just oil and if so what kind. 2.) How would I tighten the chain, its...
It uses oil only to lubricate the chain. The type of oil in not critical although special chain saw oil is available. If you use anything but chain saw blade oil, make sure that it is a light oil, both in viscosity and in colour because it is a total loss system and dark or dirty oil can become very messy. The chain adjustment is on the body at the end of the blade, it actually moves the blade in or out to set the chain tension. The chain should be tensioned that when it is pulled at the bottom, the guides of the chain should not quite come out of the slot in the blade. If the chain is too tight it overheats the blade and stretches the chain.
How do I tighten the chain on my Remington 14 in. 2 hp electric chain saw? Have used tightening screw, does do anything. Loosened the blade bolts trying to move the blade out slightly. Doesn't work...
Mitch if you attempted what is in the manual, and it is not working we would have to see and touch the saw to determine what has failed. If you loosened the bar bolts before trying the adjuster and it did not work, I suggest a trip to a local saw shop.
Chain adjustment pages 1, 8 and 9.
This is from a Remington OM
http://shoppingcart.msservicecompany.com/msservice_net/product_files/107624%2001/107624-01-EL-8-OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 03, 2010 | Remington Electric Chain Saw
I need a new part that holds the two screws which fasten the chain. I also need the little metal piece which tighten the chain using a screw driver. please respond to me dlehman@adamswells.com
Find and reference the IPL for your saw here:
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
They are no longer in production and replacement parts are almost exhausted. If your parts are NLA; try an Internet search for "Remington YourPartNumber". We can do no more. Good luck
Lou
Please do not punish my rating because you are unhappy with Remington. I provided a very helpful answer, just not the one you wanted to hear.
Nov 24, 2009 | Desa International Remington 14" Electric...
What size chain for replacement
If it is a Remington model M30016US with a 16" bar "91VG058G" is the recommended chain from Oregon. If not you can get a pn here:
Bar & Chain Selector
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
That model did not match anything here:
Remington.com
HTH
Lou
Sep 30, 2009 | Remington M30016US 16" 3.0 Peak Hp Modular...
Replacing Remington Electric chain saw blade
Where the bar meets the body of the saw there is an adjustment lug that will either push the bar outward tightening the chain or may be retracted allowing slack in the chain. When backed off (loosened) sufficiently, the chain may be removed for replacement. In order to use this feature, however, there are two bolts that secure the bar to the body that must be loosened prior to any adjustment and tightened bach up after making adjustments to the chain. The above will be enough to remove and replae the chain. If you are taking off the bar (that the chain runs on), you will need to remove the two bolts that were just loosened for the chain adjustment (above).
Regards! --WoobieDog--
Jul 07, 2009 | Remington 16" Electric Chain Saw Assembled...
Remington 14 inch electric chainsaw replacement blades
You can 14SC available online at www.masterparts.net you also can contact them toll free at 800-446-1446. They ship parts out very fast.
May 25, 2009 | Desa International Remington 14" Electric...
Electric chain saw chain adjustment. How loose should it be?
the chain should not be sagging from bottom of bar.when you tighten the chain push the nose of saw up so that all of the slack is out of the chain.chain should snap back in the bar if you pull the chain up and let go.when i adjust a chain i push the saw forward to make the bar go up and stay there while i tighten the nuts.hope this helps, let me know
May 11, 2009 | Desa International Remington 14" Electric...
Remington ld4016 w
There are one or two large nuts on the chain side. There is also a screw adjustment on the front where the bar or chain guide meets the saw. You loosen the nuts a bit (so that you can move the bar). Then you back the screw out to allow the bar to move back into the saw enough for you to put the chain back on the bar in the guide slot. Then you tighten that screw to the point that you can still push the chain around the bar (wear gloves) and there is very little slack under neath. Then you tighten the nuts. As you tighten them, pull up on the "nose" of the bar.
Make sure you keep oil in the reservoir and oil a lot as you cut. Keep the chain adjusted, they stretch as you use them. RTFM
Oct 18, 2008 | Remington 16" Electric Chain Saw
Remington Electric Chain Saw  Logo
458 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
