Question about Whirlpool RBD275PR Electric Double Oven
Need to replace control panel assembly
How to replace control panel assembly on whirpool double oven rbd275prb
  • 523 Answers
Four screws just under panel then lift up and out
it should come out
Posted on May 27, 2010
Fault code E4 F3
The F3 codes mean that the oven temperature sensor has a problem. In the case of the E4 error, it is an open circuit. (If the GR465XLS0 is a double oven model, it's the lower oven with the problem with the sensor.)
You need to replace the sensor. Unfortunately, I'm not sure that you have provided the correct model number. Most Whirlpool ovens have an extra character in the model number. If your model is the GR465LXLS0, the temperature sensor will cost ~$65. One source is http://www.appliancepartspros.com/Appliance-Parts/whirlpool-oven-sensor-assembly-item-number-ap4326911.aspx .
I hope this helps.
Sep 07, 2012 | Whirlpool Ovens
Whirpool gold double over shows codes e1 f2
Ifim not mistaken its either a loose touch pad conn. or it needs a new touch pad.
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Try this, and you will know which one is the problem.
Feb 04, 2012 | Whirlpool Ovens
Error codeE6 F2
Remove the power from the oven. Open the control panel and unplug the key pad ribbon from the control board. Assemble the control panel back and turn the power on. Wait a few hours.
If the error code came back on, replace the control board.
If the error code did not show up, replace the control panel (the key pad comes as a control panel assembly).
- The part number for the new control board AP3595759
- The part number for the black/stainless control panel AP3131755
Good luck.
Gene. __________________Hi I did some research for your oven and this is what i found , someone with the same problem , control board needs to be replaced , if you click on the web page below it will explain it to you , good luck Frank
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1094-whirlpool-fault-code-e6-f2.html#ixzz1gYuqvZnV
Dec 14, 2011 | Whirlpool RBD275PR Electric Double Oven
!0 year old GE Profile Double Oven. Control Panel repaired but oven is again not working with a "F7" mal function indicator on panel. Model # JT 950 S0A3SS
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Sorry for the bad news....but hope you understand. Please get back to me if you have any other questions.
Kevin
Jan 03, 2011 | GE Ovens
My oven beeps and show error code F7 on the panel. Help!!!
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | GE 27" Built-In Double Electric Convection...
I used the self cleaning for the top oven of my double whirpool Accubake ovens today. It worked fine during the process. But now, after it has cooled down. The panel is not lit up with the clock etc. and I...
There is a non-resettable fuse on the back of the oven that will have to be replaced. The oven will have to be removed from the wall and the back panel removed from the oven to access the fuse.
Nov 22, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirpool Accubake Control Panel
try turning power off and wait 10mins and see if it resets.
Sep 14, 2009 | Whirlpool RBD305PD Electric Double Oven
E6 f2 trouble code on a whirlpool oven
BEING A WHIRPOOL AGENT MYSELF IN SOUTH AFRICA I CAN TELL YOU THAT ITS BEST THAT YOU CALL A WHIRLPOOL AGENT OUT TO HAVE A LOOK AT THTE APPLIANCE THEY ARE EQUIPED WITH A HAND COMPUTER THAT WILL DETECT AND FIX THE PROBLEM 90% OF THE TIME WITHOUT REPLACING THE CONTROL BOARD WHICH IS VERY EXPENSIVE.GOOD LUCK.MOHAMED
Sep 12, 2008 | Whirlpool RBD245PDS Electric Double Oven
Had a power failure and now getting a PF E1 error on the control panel
F5 - E1 and E2 Check door/latch switch Replace switch if defective
It has detected a problem with the switch on the door lock motor. In most cases the switch will need to be replaced.
Nov 22, 2007 | Whirlpool GBD307PRS Stainless Steel...
Whirlpool RBD275PR Electric Double Oven Logo
144 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
