Question about GTCO InterWrite SchoolBoard 1077 (SB1077TVU12)
Is it possible for the sensors inside the board to go bad? I can no longer write on the board? It feels like the bluetooth conection is loose???
  • 49 Answers
The Schoolboard has what are called "GRID LINES" that can open up and cause dead spots on the Schoolboard.
If you a cabled connection, try to test the Schoolboard that way.
Posted on Oct 24, 2013
Bosch Dishwasher Model # SHU53E02UC/14 started running about 3 times longer than it should and its not cleaning very well.
If the Rinse cycles completes within the normal time, but other cycles are slow - particularly a Heavy or Super Scrub cycle - it is most likely that the water heating is not happening or is very slow. The control will not advance (proceed) the cycle until the temperature sensor signals the control board that the water temperature is correct. Otherwise the control will wait, indefinitely, for the heating to happen. This also affects cleaning and drying performance. Loose wire connectors, bad heater, bad temperature sensors or a bad controller are possibilities.
Oct 10, 2016 | Bosch Dishwashers
Reduce engine power 2003 gmc Yukon xl.....replaced
First check ALL fuses,,,,make sure there good,, then check,Computer or wiring to the computer,,,sometimes where the wiring harness conects togeather they will break or loose connection,,or back out of the connector,,,,feel the wire just behind the connectors see if its broke, or loose or backed out of the connetor,,,very time comsuming ,,also the loom going to the throttle body,, check for naked wires touching around/ going to throttle body
Sep 14, 2014 | Cars & Trucks
Our KitchenAid Electric Range display panel keeps indicating to set probe temp (and beeps every time) when probe is not even plugged in oven. When placing the probe in the oven jack it feels very loose. ...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 09, 2011 | KitchenAid KESC307 Electric Kitchen Range
Shurt off when is runing
Idle Control...Remain Unstable...Check for Vaccum Lost,, Possibility PC's Valve Defect Check For Electronic Injector Sensor for bad conection Check Alternator Regulator for failing Signal may cause damage to all sensor and Firewall & Logic Board Check Battery for power lost ...
Oct 01, 2010 | 2003 Mercury Mountaineer
Frigidaire model FEF336BGWF. Oven gets way too hot! Had on lowest temp of 200° and a themometer inside oven read 375° and got up to 400°. Can it be adjusted? If so, how would i do it? Or do...
unit has a sensor inside oven cavity that changes resistance according to temperature can be checked for resistance with mutimeter basic troubleshooting check all conections to sensor loose or poor connections can cause false temperature readings
after verifying connections run test
possible sensor bad or bad electronic oven control no fault code reported
http://www.repairclinic.com/0078.asp
list of fault codes for multiple brands
Dec 11, 2009 | Ovens
The gauges are not working and the fuses on the inside panel are good
Not much to go on but here goes;;;The most common thing is the ground wire on the printed circuit behind the instrament cluster,or a broken circuit board. next,check to make sure the wire harness has not shook loose going into the cluster. then theres the wire harness that goes through the fire wall,,that could have a bad conection,,there is also in some vehicles,,a voltage regulater just for the cluster,,,and then theres that nasty computer that controls all the functions of your engine and sensors. My guess would be the circuit board first then a bad ground on the circuit board . A word of advise,,,be sure you checked ( all ) the fuses with a ohm meter and not a test light ! A test light can destroy your engine computer. And sometimes the fuse can look good but still be bad. Also ask your dealer if there are any hidden fuses that you cant see. They sometimes put them in strange places. Hope that helps !!
Aug 17, 2009 | 2001 Dodge Ram 2500 Truck
Bluetooth/wifi doesnt works
Same problem occured at HP laptops. Unfortunate, problem comes from the board. Somewhere has got crack or broken link. Last time I have checked, I find , Top of the board and bottom of the board has got copper lines and devices soldered, but there is also middle lines that not possible to access and repair without shematic diagram. I end up changing the board that solve the problem. But Before that I install driver, restore again (seems worked forawhile) remove the wireless card check solders, setup network again. None worked. I do not want to give you bad feelings but, if it is Vista, reload the drivers and see if will work.
Hopefully it will. Do not touch the switch much, there are P.O.S. Small spring inside the switch is loose everytime and it is not gold plated, get rusty couple of months. Goodluck
JMC
Aug 17, 2009 | Lenovo 3000 Y410 Notebook
Error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Jun 01, 2009 | Canon iR 1600 Laser Photo Printer
CANON IR 400 COPIER - ERROR - E677
Sep 11, 2008 | Canon imageRUNNER 400S Copier
I have a Pioneer KEH 2700R and when i press the on button it doesnt turn on all wires are conected and unit does works as when i puss and hold the function button it all lights up
It is a loose connection or cold solder and cleaning problem this is the main caused. Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....
Good luck:
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 10, 2008 | Pioneer Audio Players & Recorders
GTCO InterWrite SchoolBoard 1077 (SB1077TVU12) Logo
83 people viewed this question
Top GTCO Computers & Internet Experts
William F. Bryant Jr
Level 1 Expert
Ciricuario Dh
Level 1 Expert
Are you a GTCO Computer and Internet Expert? Answer questions, earn points and help others
