Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Filter is making clunkity type noise when filter is started
We just set up our pool and filter and when we turn the filter on it makes noises. Is this supposed to be a quiet filter or is it engineered to make noise. it almost sounds like a clickety clunkity sound
  • Intex Master
  • 1,338 Answers
It sound like it may need bearings. trouble is getting anybody to work on one of these. if you take the cover off of the motor side and listen to it and look at the shaft on the motor , if its all rusty ? its junk see if you can find pump and motor replacement on ebay.. i help any ? vote .. thanks jay
Posted on May 26, 2010
My bestway pool heater is flashing red and making a continueious ring noise is this what it is ment to do thanks in advance
Best way pool heater???
Never heard of it!
Is this an import heater from China?
Like maybe for one of those Toy Pools?
... Anyway, if it never flashed red before, then there's a possible problem.
any noise other than a quiet hum, is not normal.
is this gas or electric? I'm curious
Apr 25, 2015 | Pool & Spa
BHR170 hose set up
in from pool to intake of pump out of pump to in of filter out of filter to in of heater if you have one if not to pool returns if in filter and comes out backwash put a valve on it till you can change multiport or gasket
Jun 01, 2014 | Sta Rite Sta - Rite 24" Sand Filter & 1 Hp...
Pool pump makes a loud noise
bad bearings change pump and motor
May 14, 2014 | Waterway Impeller Pump 2HP SD WW
We have a hayward xstream pool pump for our 18' above ground pool that my daughter got through make a wish last august. we cleaned the cartridge yesterday and when we replaced the cartridge it started...
Try taking the pool filters cartridge out and following these steps to make sure that it is installed properly.
1. Clean debris from bottom of filter tank.
2. Replace element evenly on the collector hub in bottom of the filter body.
3. Place lid evenly on filter body and turn Easy-Lok™ ring clockwise until the safety latches engage securely.
4. Close and secure drain plug (located at the base of filter body).
5. Open air relief valve (Turn lever to left).
6. Open valves (Optional suction & return valves).
7. Prime and start the pump.
8. Once air has escaped the filter and a steady stream of water is flowing from the air relief valve, close the air relief valve and note the pressure gauge reading.
Jul 15, 2010 | Hayward Pool Products Hayward Xstream...
Intake valve make a vibrating noise after a few minutes
From what you are explaining it sounds like the pump is taking on air, which I have seen when the water level is just a tad low & the pump creates a "vortex" at the skimmer box & air is sucked in. Double check the "flap" at the skimmer to make sure it is working properly (not stuck upright)
Jul 13, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Raypak pool heater is making a knocking noise
low water flow check manual bypass in heat exchange if spring broke letting too much water bypass and overheating water in unit also see if pump ok and filters
Jun 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool motor is making a funny sound when I turn it on.
I have included a copy of the users manual for these pool filters below. If the filter is still functioning properly and just making a noise, it might not even be an issue. I would consult the manual and see if you can reach a solution.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
Jun 11, 2010 | Hayward SAND FILTER, PRO SERIES
Heater is shaking and making a loud noise when
not enough water flow if filters and pump ok check manual bypass for bad spring if ok see if plumbing bypass it should only be half way open
May 29, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
429 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
