Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Dishwasher does not drain
I have a F & P DD-603 dishwasher. Cleaned filters and drained drain pipe by disconnecting at waste disposer. Subsequently tried testing drainage but again it is not draining! Could their be an air-block? Any help would be appreciated. Thanks
SK
  • Fisher and P... Master
  • 3,247 Answers
Do you hear the motor running during drain cycle? If so, there is likely a blockage inside the motor (rotor) chamber and filter sump.
You will have to take the rotor out and lift the filter plate. There is a small channel between the rotor chamber and the filter sump. Take a thin but rigid wire and remove any obstacles. Mostly chicken bone fragments.
If motor is not running during drain cycle, then you are looking at a bigger problem and will require checking if the wash cycle is ever completed. If not, then the heater could be the problem. Will need technician if you are not familiar with fixing such things.
Please rate the solution if you find it ok, Otherwise post a comment and fixya.com will try to help you.
Posted on May 31, 2010
My dishwasher won't drain properly. The pump has been making a weird sound for a month or so and last night it couldn't drain. It starting beeping and the pump was running. I cleaned the drain filter
If the pump is running but noisy then that indicates a loose pump impeller (new pump I am afraid) if running (no noise) but failing to remove water, then I would be checking that drain hose is clear, or even that your machine is not syphoning water from waste disposal, a quick check would be to disconnect waste hose from waste disposal and see if it will then drain into a bucket, hope this is helpful.
Feb 18, 2013 | Dishwashers
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Frigidare dishwasher did not spin
  1. Waste Disposal/Sink trap
    • Empty your food waste disposal unit if your dishwasher's hooked up to one. If it's not empty, the old food inside it will back water up into your machine. Check that your sink trap isn't blocked by unscrewing it from the base of your sink if you don't have a food waste disposal unit. Make sure your dishwasher or any other appliances connected to it are not running when you do so.
    Incomplete Cycle
    • You may have opened your dishwasher's door mid-cycle before it's had a chance to drain. Check the progress indicator on your machine's control panel. The structure of this will differ depending on which Frigidaire model you're using, but it should show the point your machine has reached in its cycle. If this is the cause of the problem, close your dishwasher's door and let it finish.
    Drainage Pipe
    • Inspect the drain pipe that runs from your machine to your waste disposal unit or sink. If this is kinked or has been squashed under another appliance or a base unit, the waste water inside your dishwasher will be unable to escape. Check that water can flow through your waste pipe freely.
    Filter
    • Remove the bottom shelf from inside your machine and take out the plate covering the filter area. If you don't rinse your plates before you put them into your washer, food debris could block your filter and stop water from reaching your drainage pipe. You can unblock your filter with your fingers. Turn off your machine's power before you attempt to do so.
Feb 02, 2012 | Dishwashers
Water remains in machine after cycle is complete
that is normal,unless you will remove the drain pipe if not equipt with automatic drain valve.
Aug 12, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher Paykel Dishwasher drawer not draining water.... F1 error... Drawer is holding water......possible hard water build-up...
F1 means that your machine has activated the flood switch. check the drain hose that is connected to the sink pipe is not blocked. remove clip holding hose to pipe, put end of hose into a bucket and turn on cycle. it should start draining straight away. if it does drain into bucket stop cycle and clean nossel of sink pipe with a small screwdriver. then refit hose and turn on cycle. if it doesnt drain into bucket please reply and i will guide you thru how to check to see if you roto motor is jammed or faulty.good luck
May 05, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Dd-602 water will not drain. Problem 2 U3 code started to beep
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 07, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Dish water tray full of dirty water, does not
It sounds like a plugged discharge line, close to the disposer. With the power off to the disposer and the dishwasher, remove the dishwasher drain line ate the disposer drain. Careful, there will be water there, most likely, so have a pan or buchet to catch the water. Pass a wire back up into the drain line from the dishwasher as far as you can towards the high point of the drain line. Remove the wire and pass it into the disposer (sink) drain, making sure that the piping is unplugged. Reassemble and try.
Regards, --W/D--
Jul 14, 2009 | Frigidaire PLD4375RFC Dishwasher
Bosch dishwasher will not drain
how do you disconnect the waste pipe from the back of a Bosch hydrosensor dishwasher
Aug 09, 2008 | Dishwashers
Double dish draw
removed filter, removed rotor, check for obstructions in sump. If problem still exists physically check drain hose for restrictions/kinking
Jul 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Neff Dishwasher won't drain
I've had this problem a couple of times with my dishwasher. In both cases, the cause was a shard of broken glass that had managed to get past the filters and jam itself underneath the impellor. Hard to see, but easy to fix. First ladle out the water.
Pull off the lower rotor arm, unscrew the filter and take out the filter bowl, tray and cylindrical filter. Get as much water as you can out of the filter cavity.
Then, using a Torx-20 driver, remove the screw holding the impellor cover and lift the cover off. (this is the small bit of plastic at the left end of the filter cavity.) Check whether the impellor can rotate freely by spinning it with your finger several times - if it jams or grinds, then there's probably something jammed under it. (It may seem to be fine at first, so do check thoroughly, as any debris can move around with the water flow and only jam occasionally) You may have to use a cocktail stick or similar to poke out anything that's stuck underneath.
Glass is a particular problem, since it's almost impossible to see when there's any water around (it's easy to cut yourself too!)
Anyway, that's worked twice for me now - and I didn't have to even move the machine out of its cupboard to fix it.
Hope that helps.
Nov 10, 2007 | Dishwashers
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
114 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
